86 with bad shudder
Old 12-17-2011, 04:27 PM
Groundhog's Avatar
86 with bad shudder
I have an 86 Extra Cab w/carb which shudders badly just before upshifting to the next gear. I have changed plugs, plug wires, distributer cap and rotor with no change. This is a bad shudder, the whole truck jerks. Could this be a vacuum leak?
Old 12-17-2011, 05:15 PM
Sensei's Avatar
Welcome to YotaTech.. are you sure its a driveability shudder with the engine. Could be a driveline vibration that becomes noticeable at 2500 to 3500 rpm, typical shift point rpm. Check u-joints, output shaft and pinion flange for excessive play.
Definately not a vacuum leak.
ghostmoney
01-28-2018 11:42 AM
crammit442
7
11-29-2017 12:30 PM
Blamalam
08-16-2015 12:29 PM
corey519
08-12-2015 11:12 AM
nonstop
7
08-11-2015 09:26 AM
Quick Reply: 86 with bad shudder
