$550 to change clutch?? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-22-2006, 12:46 PM   #1 (permalink)
91RN81's Avatar
Need a clutch in my 91 toyota 2wd pickup and got some quotes, cheapest was the toyota dealership go figure... They quoted me $400 just labor, i can get my own clutch kit. What in the world? this is the simplest drivetrain layout possible to change a clutch. Is this the bold reality or am i getting shafted here, lol. Anyone ever got quotes for changing a clutch? thanks guys.
__________________
1991 Toyota Pickup 22RE
2wd 1/2 ton 5spd
Genuine Toyota Quality
91RN81 is offline
Old 02-22-2006, 12:53 PM   #2 (permalink)
Tacoma Dude's Avatar
Send a message via AIM to Tacoma Dude
Sounds about what I was getting quoted when I looked around for my 86.
If you got someone who can help you out, the right tools, and a free weekend I'd strongly suggest that you tackle this on your own. Its good for self-enrichment and you'll save a few $$s.
__________________
Peter!
2002 Tacoma
1986 4Runner
Tacoma Dude is offline
Old 02-22-2006, 12:54 PM   #3 (permalink)
shazaam's Avatar
Send a message via MSN to shazaam
I once helped a friend change the clutch in his tacoma pick up .. it was a pain in the ass. $350-400 sounds about right
__________________
Experience is a hard teacher because she gives the test first, and the lesson afterwards.
<-- the artist formerly known as sdastg1
shazaam is offline
Old 02-22-2006, 07:05 PM   #4 (permalink)
bruzer1123's Avatar
I had mine done right after I bought it (winter) and needed it done right away...paid way more than I should have-$600 or so I think. Yikes!!
bruzer1123 is offline
Old 02-22-2006, 07:22 PM   #5 (permalink)
chugs's Avatar
u should just do it yourself. Hardest part will be puttin' the transmission back on. You'll save a few hundrede bucks!
chugs is offline
Old 02-22-2006, 07:40 PM   #6 (permalink)
4Mogger's Avatar
I recommend the Centerforce dual friction clutch and a switch to the heavier Centerforce flywheel. Also be sure to replace both the throw out bearing and the pilot bearing and ONLY USE TOYOTA FACTORY BEARINGS!
4Mogger is offline
Old 02-22-2006, 07:48 PM   #7 (permalink)
trx125's Avatar
You can change the Clutch in a few hours with a couple hands and your trusty MacGyver pocket knife! You can use your leaf blower / hose to power a cheap impact and air ratchet. Can of hair spray and lighter for a torch and battery/ clothes hangers for a welder! lots and lots of BEER!
trx125 is offline
Old 02-22-2006, 08:39 PM   #8 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
i would change it your self i did it with a freind took around 4 hours...this was my first time and it wasint that hard
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
sister 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 02-22-2006, 10:05 PM   #9 (permalink)
kyle_22r's Avatar
the toughest part is removing those top 2 bellhousing bolts, and aligning the input shaft with the clutch disk splines when installing.
most shops will quote between $400-600 in labor though.
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 02-22-2006, 10:46 PM   #10 (permalink)
Dr.Feelgood's Avatar
Do it yourself with a friend or two. Get the 2 top bellhousing bolts using a long extension through the shifter hole after you remove the boots and levers.
__________________
'90 4Runner SR5 22RE 5spd 4x4, Pacesetter header & downpipe, Magnaflow 18" oval, 2.25" pipes, Rock Crawler 51 15x8 Steel Wheels, Pro Comp 33x12.5 ATs, Aisin Hub Swap, 2" BL, Energy Suspension Mounts/Bushings, K&N Filter, Accel Coil, NGK Iridium Plugs & Blue Wires, Toyota Brush Guard, Allpro Offroad Rear Bumper w/ 2" receiver, SB SureSteps, Whiteface Glow Gauges, Husky Liners, New Front Fenders, Radiator
Dr.Feelgood is offline
Old 02-22-2006, 11:18 PM   #11 (permalink)
surf4runner's Avatar
Quote:
i did it by myself in a few hours. the body lift made access easy. two mechaniclly inclined heads should be able to do the same. i bought a lifetime warranty clutch pack (PP, TO bearing, clutch) from autozone for ~$135. been in for over 100k w/o issues and when it does wear out ill take it out and get a new on for free.
i used some 100 grit sandpaper lightly on the flywheel to create a new surface.
__________________
sarcasm noted...and appreciated
im with the banned
Quote:
Originally Posted by fustercluck View Post
I was traumatized. I had nightmares of trained attack tupperware beef-logs chasing me all night! Don't bend over, Fuster!!!!!
Quote:
Originally Posted by Lysmachia View Post
Just pile us nekkid in an engine bay and drizzle us with gear oil and watch the fun!
surf4runner is offline
Old 02-22-2006, 11:44 PM   #12 (permalink)
hytech_redneck's Avatar
i just had my 94 runner's clutch replaced. it was 280 for labor 220 for the part. i got a clutch master clutch kit. made for offroad performance. i also replaced the flywheel and a cv boot and had the sway bar maintananced. all for about120 more so u add that up its pricy but i think it was worth it. 280 was the cheapest labor i could find with a year waranty
hytech_redneck is offline
Old 02-23-2006, 04:58 AM   #13 (permalink)
Intrepid's Avatar
Send a message via AIM to Intrepid
From what I understand, a Tacoma clutch is a much bigger PITA than a clutch on an earlier truck. I have heard the "couple hour" thing from 1st gen guys, but a Tacoma is a between a 6-20 hour job depending on how mechanically inclined you are and whether you have ever done it before. I got a couple quotes for my Taco and they ranged between $700 total and $1100 total, which made me decide to do it myself, haha. So $400 just labor sounds pretty accurate for what I assume is a slightly easier clutch. I agree with everyone else, do it yourself. Get a chiltons manual, a friend, and a tranny jack and have at it.
__________________
www.toyotacrawlers.com
'85 4runner: 4.7's, FoxFab sliders, custom bumpers, 1" body lift, F-150 springs rear, lockright, welded third, IFS rear axle, 1.5" wheel spacers, high-steer, rears up front, Longs, 38" SX's on steelies, 12Voltguy dual battery, soft top, BMW seats. NO LONGER lacking an engine. :D :D
Intrepid is offline
Old 02-23-2006, 06:10 AM   #14 (permalink)
trythis's Avatar
first time I changed a clutch on a chevy s-10 took me 14 hours, I had no idea what I was doing. If you haven't worked on this kind of thing before, plan for some extra hours for unexpected things, like replacing that rusty exhaust pipe, and oops, look like that exhaust manifold bolt was broken a while ago, hmm, what's that rattleing noise in my catalytic converter? Things like that, that you will save money on, doing it yourself.
trythis is offline
Old 02-23-2006, 07:14 AM   #15 (permalink)
86SR522REEFI's Avatar
Send a message via AIM to 86SR522REEFI
I got mine did for $400 and bought a Duralast Clutch Kit for 79.99 at autozone. I have replaced the slave cylinder and clutch master cylinder myself. I say go for it though. I am regretting having someone do mine.
__________________
<(((Mark)))>
1997 4x4Runner
Limited 5-VZE
Auto 134,000 Miles
Quote:
Originally Posted by Leslie Nielsen
I am serious, and don't call me Shirley.
86SR522REEFI is offline
Old 02-23-2006, 07:26 AM   #16 (permalink)
cootees's Avatar
Send a message via AIM to cootees
I just had a new clutch kit installed last week. I paid $350 for the labor of the clutch kit, and installation of new u-joints.
__________________
-- '90 4Runner 2Dr
3.0 / sas /OME 860 coils / rear e-locker / 32's/ MC Rear bumper / TG Sliders / surco basket / cobra 18 wxstII / ISR / Magnaflow exhaust
cootees is offline
Old 02-23-2006, 09:37 AM   #17 (permalink)
Bobakazi's Avatar
Send a message via AIM to Bobakazi
Had mine recently done for $325 total
__________________
'90 Extra cab V6 4x4 PU
5.29 gears. Detroit locker front, Detroit Truetrac rear.
35" BFG mudders. Trailmaster 4" susp, 3" body lifts. Add-a-leaf. K+N intake, 2.5" exhaust with Flowmaster 40 and a cat I got off an Evo VIII.
Bobakazi is offline
Old 02-23-2006, 10:45 AM   #18 (permalink)
kyle_22r's Avatar
check on ebay -- exedy(OEM aisin clutch) kits typically run under $100. i've got one in the mail, should be here today. paid $84($64 for the kit and $20 shipping). they've also got KOYO pilot and throwout bearings, same as the dealer's.
i have one of these clutches in my '79, and don't have any apprehension about putting one in my '91.
__________________
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 02-23-2006, 11:08 AM   #19 (permalink)
dwh91102's Avatar
Send a message via Yahoo to dwh91102
you can get to the top two bell housing bolts with some extensions, and a woobler. I'm with everyone else on doing it yourself, its a easy job with a friend to help ya.
__________________
89 SR5 p/u 3.0 5 speed, doa cams, downey headers, jacobs igniton, self made isr pipe, electric fan, 14"flowmaster, allpro rear spool, 63"chevys, 4crawler 2"bl, bj spacers, skymanufacturing u-bolt flip & shock tower, ranchos, 1 1/2 square tube bed, aisin hubs, 35x10.5x15 super swamper boggers.....For ever a work in progress
2000 Tundra SR5 V8 4x4 Bone stock DD/Tow Rig
Looks like Oly's hole is gonna be busy....LOL!
dwh91102 is offline
Old 02-23-2006, 01:37 PM   #20 (permalink)
91RN81's Avatar
guess ill have to bite the bullet and pay up, don't have the mechanical knowledge, tools, downtime to do it myself, thanks guys..
__________________
2wd 1/2 ton 5spd
91RN81 is offline
Old 02-23-2006, 07:40 PM   #21 (permalink)
Shop around for bids. I am somewhat mechanically inclined, but no expert and I did them on an 81 Toy and an 85, both 2WD. Helped a friend do an 83 Toyota 4x4. A floor jack will work to help lift it up and guide it into place. Buy the $4 tool to align the splines with the clutch disc. Worth it. At any rate if I can do it, I think others could. I understand if you don't have the time or space to do it. A concrete pad is nice to roll the jack around on. You have to kind of rotate the tranny as you slide it up into position. Overall, it took me the better part of a day the first time, but I was taking my time and reading the book. The How To Keep Your Toyota Alive Forever one, ... great book. I would be curious what "book time" is on that job. Probably 4 hours. I wouldn't pay more than $300 or so for labor.
makarov is offline
Old 02-24-2006, 11:24 AM   #22 (permalink)
kyle_22r's Avatar
any clutch kit worth its salt should have the alignment tool!
__________________
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 02-27-2006, 04:01 PM   #23 (permalink)
Rusty Davis's Avatar
All the estimates I see are about the same around here.
Having been a mechanic myself and having a current leaking rear seal-
I HIGHLY RECOMMENDED that you replace your Rear Main Seal. The labor for this is probably only listed as .5 to 1 hr. extra and that's cheap insurance to insure you won't be paying another $300(est.) in the future to get it done. Any honest shop should mention this to you. Other shops hope to see you again soon when that seal starts leaking!
HTH
~R
__________________
1994 4Runner 3.slow
Help me afford a Rear Bumper!
Items 4 Sale here and here
Rusty Davis is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Hella 550 rezrunner92 86-95 Trucks & 4Runners 0 02-19-2007 07:55 PM
clutch change? Sonofmayhem Pre 84 Trucks 9 10-25-2006 08:01 AM
How hard is it to change a clutch at home? markjs 95.5-2004 Tacomas & 96-2002 4Runners 20 01-10-2004 08:04 AM
2009 InternetBrands, Inc.
