4runner Door Alignment
Old 01-27-2010, 05:28 PM
DanStew's Avatar
The 4runner i got had its driver door hyperextend itseld and get messed up pretty good. The PO of the truck did hammer it out so that the door would close, but an issue is it is hard to close right at body contact. I can see the door gsaket closest to the hinges is getting squeezed and causing the bind. After looknig at the door when shut, you can see a good 1/2 inch gap between door and body. After doing some searching i found the adjustment on the doors are the hinge mounts on the body. My problem is i can get to the bottom hinge through the kick panel, but where do I access the top hinge? Do I have to pull the dash to get to that one?
Thanks!
Old 01-27-2010, 06:17 PM
myyota's Avatar
It sounds like the door is messed up pretty bad, and adjusting the door hinges isn`t going to help. There is very little adjustment in the door hinges, maybe a 1/4'' at the most, so to really fix the problem you will need to replace the door.
Old 01-27-2010, 06:18 PM
eighty5yota's Avatar
also.. not to bum you out.. but the pillar that the door bolts to might also be bent.. and a junkyard run wont help there... =\
Old 01-27-2010, 06:56 PM
DanStew's Avatar
Thanks Guys. I have a parts runner that i can grab a door off of, I was just hopin to maybe not have to for now. I can live with it till i get the other parts.
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
tobylab
01-18-2016 07:06 PM
hangtown88toy
07-10-2015 02:33 PM
Cplmike
07-08-2015 08:47 PM
Quick Reply: 4runner Door Alignment
