4:56 versus 4:88's
Old 04-10-2009, 08:38 AM
Padawon's Avatar
4:56 versus 4:88's
I am looking for some gearing advice.
I have a guy who is selling complete front and rear third members with 4:56 gears, For around $300
Should I go for the 4:56 or save my cahs and invest in a set of 4:88's?
My rig
87 4runner 22re on 31's 5 Speed
I don’t plan on changing the tires size and it will mosty be city and highway use. I'm looking for Fuel economy and highway driving while going up hill.
Will 4:56 give me a good bang for the buck? Someone told me it will keep the RPMs down and increas my highway speeds in 4th and 5th
Old 04-10-2009, 08:46 AM
904_runner's Avatar
Well 4.56's are what toyota put stock for 31's.
So its really up to you.
Old 04-10-2009, 09:04 AM
PirateMcgee's Avatar
I have the exact same question so some input would be helpful
also will the 3rd from a 4.56/88 swap directly into my 4:10 (22re) rear diff?
Old 04-10-2009, 09:09 AM
89silverpu's Avatar
Yes as long as its 8 inch diff from a 1st to 3rd generation or e locker from a tacoma but that requires modification of the axle housing.
Old 04-10-2009, 09:11 AM
89silverpu's Avatar
My rig
If you live at a significant altitude or want a better performance offroad but a little higher RPM's at freeway speed, go 4.88's. If you want stock performance and don't live at a high elevation go 4.56.
Old 04-10-2009, 10:04 AM
Padawon's Avatar
Thanks 89 silver PU
My altitude is between 800-2800. San Jose Bay Area CA. so 4:56 should work
Thanks for the advice.
What year Tacoma 3rd members with Elockers could I put in my 1st gen? And what is the modification?
Old 04-10-2009, 10:20 AM
terrybo3's Avatar
Thanks 89 silver PU
I would also like to know the answer to this question...
Old 04-10-2009, 11:12 AM
89silverpu's Avatar
To my knowledge up until '04. I don't know about the 5th gen rear e-locker third.
I'm putting in a '97 e-locker third in the rear of my '89.
Here's a coupld links to whats involved:
http://www.sonoransteel.com/phong/re...ic_locker.html
http://www.4x4wire.com/index.php?opt...tech&Itemid=53
However, 1st through 3rd gens are plug and play
Old 04-10-2009, 11:14 AM
89silverpu's Avatar
And I'm pretty sure the e-lockers only came in 4.10, 4.30, and 4.56 gearing. I don't think they came from the factory with 4.88's but I could be wrong.
Old 04-10-2009, 11:18 PM
Matt16's Avatar
As has been said before, if you don't live on a low, flat area and do a mix of city, off road and hwy, go with the deeper 4.88s if you have the 22re.
Old 04-11-2009, 06:35 AM
What would the rpms be with 4.88's at 65mph with a 5spd 22re? How about with 4.56's?
I do a mix of everything, city, hwy, some logging road style stuff too.
Old 04-11-2009, 07:27 AM
t-1hundred's Avatar
i have a 94 t100 3.0L 5speed with a gear ratio of 4.70 and at 65mph it screams at 3k... i was gonna go 4.56's but the motor has no balls and i bearly have torque with the 4.70s so i was thinking 4.88s but then id lose my highway speeds so i decided to stick to my 4.70s
Old 04-13-2009, 06:34 AM
Padawon's Avatar
Well I bought some 4.56 3rd members on Saturday. I guess I will find out on my own about the improvement. I live in a pretty flat valley but have to climb some steep straight highways to get out of the area. CA 152, 156, 680, 580, all of them are 65MPH.
Old 04-13-2009, 07:54 AM
Please let me know how they work for you!!!!!!!!!!!!!!!!
Old 04-13-2009, 10:21 AM
Jay351's Avatar
The 3vze is just waking up at 2700rpm... It needs to rev. Don't be afraid to cruise at 3000+rpm..
Old 04-14-2009, 06:31 AM
Padawon's Avatar
I will let you know, don’t be afraid to ask me in about a week or two incase I forget. Right now I am trying to decide If I should put in a rear locker when I do the 3rd member exchange.
Major decision time…again. And that’s a big arse topic to cover. I think I will wait and save up for an E locker. The aussie thing sounds good but for some reason I want to be able to disengage at will.
Old 04-14-2009, 07:17 PM
t-1hundred's Avatar
really??? cause im afraid to blow the truck up...well my dads more afraid then i am... he said "the trucks not designed to do 80mph its geared low! blah blah blah dont come knocking on my door when you dont have a vehicle to drive". ha hes funny when hes mad
Old 04-14-2009, 08:18 PM
Jay351's Avatar
hehe, yeah! My truck cruises at 3,000rpm at 70mph. I never go much faster then that though, my truck gets tossed around by the wind..
Old 04-14-2009, 09:33 PM
Matt16's Avatar
Don't be afraid to rev these engines. I used to go up a couple kilometer long hill at 5000rpm daily (22RE). Nothing bad ever happened, even made it to class on time once in a while.
Old 04-15-2009, 07:11 AM
Padawon's Avatar
One more question. I think I know the answer but I want to double check.
I currently have 4 cylinder DIFs . I can swap out the 4 cylinder directly with a V6 DIF right? Complete 3rd member without modifying anything.
Quick Reply: 4:56 versus 4:88's
