3vze MLS head gaskets!!
Old 04-10-2007, 08:05 PM
Bumpin' Yota's Avatar
If you search on Ebay for "3vze" you will find quite a few Multi Layer Steel headgaskets for the 3vze.
Obviously these require a much smoother surface than the graphite gaskets, but I was wondering has anyone tried them??
Old 04-10-2007, 09:52 PM
shoes138's Avatar
wouldnt you want to use a multi layer steel gasket for say a turbo application? which means your on your way for a turbo then?
Old 04-11-2007, 10:06 AM
Bill's Avatar
They are good for turbo applications, and might be overkill on most NA applications. But in the case of the 3ZVE, considering the headgasket problems they are known for: would it really be a bad idea?
Old 04-12-2007, 05:53 AM
silversup's Avatar
most defiintely. MLS is the way to go if u are on your way to the machine shop. Guys with NA supras are using them bc they r sick of BHG as well.
Old 04-12-2007, 06:47 AM
mt_goat's Avatar
I guess you'd want to make sure you have good corrosion inhibitors in your coolant with steel headgaskets huh?
kgcwb44
01-29-2023 10:02 AM
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
smiley52
07-11-2015 05:16 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: 3vze MLS head gaskets!!
