3.0 Diagnosis question
Old 02-08-2008, 05:42 AM
Keener's Avatar
i remember with my old 22re if the check engine light came on, i could run under the hood and connect the two prongs in the diagnostic thing with a little jumper wire, and the engine light would flash a bunch of times giving me code.
does this work with the 3.0s, and will it work if the check engine light isn't on?
and if so, does anyone have a link to all the codes?
thanks
Old 02-08-2008, 06:30 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
This is the one I use:
http://www.off-road.com/toyota/tech/codes/index.html
Even tells you how to pull the codes.
tobylab
01-18-2016 07:06 PM
coleypull15
11-03-2015 07:41 AM
rushw
07-18-2015 01:46 PM
tobylab
07-12-2015 12:53 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: 3.0 Diagnosis question
