3.0, black box by coolant resivor, what is it and do I need it?
Old 02-09-2009, 10:44 AM
Ilovemountains's Avatar
I got it! I re read again and realized that I mis read the first time when I said I was confused!! Thanks for your help... Ill see if I can rig up a new bracket since all it sounds like it is, is a hollow box. Thanks again!
GSGALLANT's Avatar
Originally Posted by Bobzombie
This is the part/parts(the parts spoonist circled in yellow) I listed the part numbers for. It is two pieces (they have like a tounge and groove fit/dovetail) Toyota calls the bottom piece a intake air resonator and the upper piece a resonator bracket. and they are a part of the vsv system.
Correction for you...part of the PAIR system. The vsv is not a system... it stands for vacuum switching valve. There are vsv's in many different systems on a Toyota.
Old 02-09-2009, 10:45 AM
GSGALLANT's Avatar
No problem. You do have both hoses connected where they should go, right?
Old 02-09-2009, 12:12 PM
sure do
I do... My mounting bracket just snapped off in the cold, it was the little plastic ear on the side of it. I wasn't sure exactly what it did or if it could be removed all together!! Ill just get a small L bracket and some thick self tapping screws and just thread them right into the plastic... Thanks again for all the help!
Old 02-09-2009, 12:37 PM
  #25
GSGALLANT's Avatar
Sweet. Sounds like an easy fix for you, then.
Old 02-09-2009, 12:45 PM
  #26
iamsuperbleeder's Avatar
Originally Posted by a4runnerfreak
Don't hate on the mad paint skills!!!! Lol
you have much to learn
Old 02-09-2009, 03:37 PM
  #27
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
At least I knows how to spell!!!!! H8R!!!!!!!!!!
Don't make me call SHENANIGANS on you, bleeder......
Old 02-09-2009, 03:49 PM
  #28
abecedarian's Avatar
haven't I already, at least once, suggested "paint dot net"... http://getpaint.net/ ?
Old 02-09-2009, 03:50 PM
  #29
you'll get the shillelagh if you do.
Old 02-09-2009, 04:02 PM
  #30
Well, I bet my shillelagh is bigger than yours, Abe, so......on that note, if you really wanna see who'd win......
SHENANIGANS!!!!!!
Old 02-09-2009, 05:26 PM
  #31
I'm going to pistol-whip the next guy who says shenanigans...
Old 02-09-2009, 05:30 PM
  #32
Squeebs's Avatar
It is just a hollow box.
The brackets on mine were busted, so I took it out. Afterwards, i cut it open.... its just an empty box. Toyota said it was just used as an elbow so the hose didnt have to be so long and curved funny.
Old 02-09-2009, 08:39 PM
  #33
space-junk's Avatar
squeebs... you fail...
Old 02-09-2009, 09:58 PM
  #34
Squeebs's Avatar
What did i do now?
Old 02-09-2009, 10:10 PM
  #35
nv4runner's Avatar
Mine also broke off not long after I had my K&N hooked up. I just got a garden hose repair coupler with hose clamps and joined the two hoses where the resonator used to be. I still pass smog, it idles fine for the most part, and the PAIR makes the intake growl during decel and sometimes at idle.
Old 02-10-2009, 04:09 AM
  #36
GSGALLANT's Avatar
Whoever you talked to at Toyota is on crack. That would be a pretty big and expensive elbow, wouldn't it?
As I mentioned above, since the PAIR system operates with pulses (exhaust gas goes above and below atmospheric pressure as the exhaust valves open/close), the resonator is included in the system to help baffle out the pulses that would be present in your intake air if the resonator was not there.
And without the resonator installed, as nv4Runner mentioned above, "the PAIR makes the intake growl during decel and sometimes at idle."
Old 02-10-2009, 12:25 PM
  #37
Jay351's Avatar
is it a sexy growl?
Old 02-10-2009, 01:29 PM
  #38
Originally Posted by Jay351
is it a sexy growl?
grrrr
Old 02-10-2009, 10:54 PM
  #39
nv4runner's Avatar
The sexy growl at idle compliments the roar at WOT very nicely. Now I just need a louder exhaust system to complete the job.
Old 02-11-2009, 07:57 AM
  #40
mmcpeck's Avatar
What is the bottom resignator for, the one that you take out when you do the ISR mod and have to re-route that smaller diameter hose to the intake?
Quick Reply: 3.0, black box by coolant resivor, what is it and do I need it?
