| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
3.0 to 22r swap?
#2 (permalink) |
man i hate the a340h, and if i could i would swap it out for the w56 anyday. sorry to stick that in here but i would. now if youre gonna swap in a 4banger, the squirrels are gonna have a harder time with an auto. You know how bad the performance of the 3.0 is with the auto? it has to be even worse with a 4 cyl. If youre gonna swap, id say go all the way and get the 5 speed also. Plus, you cant regear the transfer case on the a340h because you cant take it apart. with a 5 speed you can add a crawler or regear. just my opinion
#3 (permalink) |
you probably can't due to emissions testing. You have to put in a motor of the same year or newer.
__________________
DJ 1994 Pickup 22RE, Engnbldr 261 cam, 5 speed. Tires that go around and around... Preping for SAS...... Originally Posted By Fustercluck "Proof that Gangus did not spontaneously generate....he has relatives." Originally Posted By Tacoclimber "My two year old better get a job, soon..." Reply Posted By Oly884 "I hear coal mining is a great career." Myspace |
#4 (permalink) |
pardon my ignorance on this but would you happen to know the motor from a 92 or newer? Is it a 2.4? 2.7? any idea on estimates to make that transition? Also, I bet it would be considerably more expensive to swap from a auto to a 5 spd huh? btw, i appreciate everyones input. thanks a bunch
#5 (permalink) |
toyota used both a 2.4 and 2.7 engines... however the 2.7s didnt come out as the 4 cylinder until the tacoma in 95
before the tacoma the 4 cylinder engine was the 2.4l 22r or 22re |
#6 (permalink) |
the 22R was produced from '81-90 in the US and the 22R-E was produced from '83-95. after that, the tacomas came with the 2.4l 2RZ-FE and the 2.7l 3RZ-FE.
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts past toys: 1984 4x2 1979 4x4 1991 4x4 |
#7 (permalink) |
No the trannys are not compatible. If you want auto you will have to stick in a40. With a 22R I would recommend a 5 speed so you can get a little more power.
#8 (permalink) |
You'd be better off selling the 6cy rig and buying a different truck.
Get a 1st gen instead!
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear |
#9 (permalink) |
I am planning the same swap...
I recently purchased a 94 pick-up with an LC engeneering 4 cylinder and a W56 with double boxes it already has a solid axle so all of this will be transfered over to my 4runner and I would imagine that all the wiring mounts and accessories will make the swap a piece of cake! My only chalenge will be the front suspension...
| Tags |
| 1994, 1998, 22r, 22re, 24, 27, 2rzfe, 30, cyl, engine, swap, swaping, tacoma, toyota, v6 |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22r swap | Sonofmayhem | Pre 84 Trucks | 6 | 07-28-2006 12:40 AM |
| 22r to 22re swap | JerryD | Pre 84 Trucks | 3 | 02-19-2006 11:13 AM |
| 22r turbo head swap | finefiftynine | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 02-04-2005 04:18 PM |
| 22r carb swap ???? | natedawgg94 | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 01-10-2005 10:46 PM |
| 22R to 22RE swap | markhodges | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 10-23-2002 10:16 PM |
