22RE from RT142 Corona to YN67 HiLux with 4Y?
Old Jun 29, 2008 | 06:21 PM
craz3d's Avatar
Will this fit without any issues, a Toyota 22RE from a Corona RT142 with a W55? gearbox to a YN67 HiLux 4x4 with a G52 that originally had/has a 4Y engine. I heard that it's merely a bolt on conversion, no adaption plate needed.
Will I have any issues with mounting etc? I know I'll need a new sump, that's a given. I heard that the mounting holes are out of place slightly, but I want to get this does without needing an engineers cert for registration (vic, aus). I only need a cert if I've made modifications to the stuctural points of the car, a bolt in engine would be great, the extra power would be awesome, not to mention my 4Y is almost dead.
Thanks for the info,
Keith
Old Jun 30, 2008 | 04:25 AM
craz3d's Avatar
Nobody knows?
Old Jun 30, 2008 | 05:53 AM
Belize Off Road Team's Avatar
As long as the Hilux was not a diesel it should fit with little issue.
Old Jun 30, 2008 | 06:59 PM
DeathCougar's Avatar
You're speaking Chinese to most of these guys man.
Those are non-US spec vehicles so you are asking on the wrong forum.
Even I have no idea if it will work. I do know the 4Y engine is used in the Toyota vans over here, and the forklifts as well in modified form I believe.
Old Jul 1, 2008 | 05:50 AM
If you want alot more help try www.toyotadiesel.com where i to am a member. Ask on there, you can alot of help!
JNapolitano
Nov 14, 2019 07:46 PM
Badlander
Jun 20, 2016 07:20 AM
Backcountry411
Diesel Swaps
Jul 29, 2015 01:33 PM
PlayAwhile
Jul 20, 2015 11:36 AM
