22re codes 24, 25, 26, and 31
Here is the problem first of all almost every time I accelerate under light to heavy the engine sputters and dies the kicks back on and off till I go back to very light throttle.
Code 24
INTAKE AIR TEMPERATURE SENSOR SIGNAL--OPEN OR SHORT IN INTAKE AIR TEMP. SIGNAL
--INTAKE AIR TEMPERATURE CIRCUIT
--INTAKE AIR TEMPERATURE SENSOR
--ECU
Code 25
AIR/FUEL RATIO LEAN INDICATOR--LEAN SIGNAL SENT TO ECU FROM O2 SENSOR
--INJECTOR FAULT(S)
--FUEL PRESSURE
--OXYGEN SENSOR
--AIRFLOW METER OR MAP SENSOR
--IGNITION
--ECU
Code 26
AIR/FUEL RATIO RICH INDICATOR
--SAME AS ABOVE
--COLD START INJECTOR
Code 31
MANIFOLD AND/OR AIRFLOW METER SENSOR SIGNAL CIRCUIT
--AIRFLOW METER/CIRCUIT
--MANIFOLD PRESSURE SENSOR/CIRCUIT
--ECU
Any help would be great and if anyone needs any more info I can help. I personally am leaning towards either ecu or maf sensor.
Code 24
--ECU
Code 25
--INJECTOR FAULT(S)
--FUEL PRESSURE
--OXYGEN SENSOR
--IGNITION
--ECU
Code 26
--SAME AS ABOVE
Code 31
--ECU
Make sure the VAFM is pluged in? test the VAFM per the FSM. And next time tell us what your motor type is atleast.
Time to put a paper bag over my head my gas gauge got stuck and it just ran out of fuel. Running fine now and not a single error code. Finally figured out how to kill my 22re...no fuel. It really did feel like a fuel pump/ wiring issue.
Was really stressed out i just got my custom housing (ruff stuff) and want to get all my tg knuckle parts bought.this would have set me back a bit.
montanatruck
02-26-2017 07:07 AM
Tacoma1313
08-17-2015 05:44 PM
