22r hot rod
Old 06-17-2008, 10:57 AM
julienade's Avatar
22r hot rod
i just got a pre 85 22r motor from a friend and i was planning on rebuilding it
i took off the valve cover and and it had the twin timimng chain sprocket at the front of the cam.
i was wondering a few things
1. will the 20r head bolt right up?
2. will the 22re head bolt right up?
3. if 22re head fits will i have to change it to a twin timing chain?
thanks
Old 06-17-2008, 10:58 AM
ozziesironmanoffroad's Avatar
why not just rebuild it? why do you want a 20R head, or a 22RE head?
Old 06-17-2008, 11:07 AM
NicCantDecide's Avatar
They are the same engine model, the heads should be swappable with minor adjustments if any at all.
But...since these engines are so cheap why go through the hassle? You're not going to see any difference in performance.
Old 06-17-2008, 11:23 AM
BAZ
BAZ's Avatar
From my understanding, the 20R head on a 22r block is supposed to flow better and maybe bump the compression up a little. Kinda like with hondas a b16 head on a b18c block is a poor mans type-r motor. There's lots of info on the 22r/20r combo if you search around.
Old 06-17-2008, 12:23 PM
julienade's Avatar
thats kind of what i had in mind with putting the 20r head on top of the 22r block
i figured it would raise the compression like a ls block with the b16 vtec head
it would be like a ls-vtec yota truck
haha
but if went with the 20r head i wouldnt be able to run fuel injection
which i have the setup for
and i would have to run carbureators
and i would want to run dual sidedrafts
butt those intake manifolds are so hard to find
and are really costly brand new
Old 06-17-2008, 12:31 PM
gsb15's Avatar
20r's and early 22rs are interchangable. after 85 the deck hight changed on the block and therfore almost nothing is interchangeable. the dual row chains were used on 22r's until 82. after 83 teh 22r heads have 3 or 4 more holes on the intake side to accomadate the efi manifold
Old 06-17-2008, 12:45 PM
julienade's Avatar
ok so a 20r head would fit
im not sure what year this motor is
or wat it even came out of
all i know is that it had the dual row timing chain when i took off the valve cover
Old 06-17-2008, 01:01 PM
AusTex's Avatar
My favorite page to link for such questions follows
http://www.toysport.com/technical%20...tech_notes.htm
Old 06-17-2008, 05:47 PM
julienade's Avatar
thanks
this is a good source
Old 06-17-2008, 06:16 PM
Matt16's Avatar
Hehe, that post title sound like "virgin stripper" or "100lbs body builder".
Old 06-17-2008, 06:45 PM
just a 22re's Avatar
ok mnot a hijacking but a honda like what the question
the b16 head fits and makes a better b18?? i dont get it
get a ls b18 block and drop a b16 dohc head on it and smoke a stock b18ls vtec? now thats some info
back on topic....
what about just taking a b16 vtec head and drilling it to fit a 22r block??? it could work with a lil help from welder and grinder right?
Old 06-17-2008, 06:53 PM
julienade's Avatar
there are 2 types of b18s
there are the b18b's
known as the ls-non-vtec motor that comes out in the normal integras
then theres the well known b18c's
known as the gsr. this motor is the well known vtec motor
so the guys take the ls blocks and put b16 heads on it. raising cmpression and putting vtec on what was a non-vtec motor. that combo is known as the ls vtec
another common combination is taking the b20 nonvtec crv motor and putting the b16 head on it. doing the same thing to the b20 is known as a b20 vtec.
putting a b16 head on a 22r block would be a miracle and i dont think would ever happen.
maybe if someone had enough skill to make a hybrid 22r head thats twin cam with vtec technology!
back on topic....
Old 06-18-2008, 10:28 AM
dcg9381's Avatar
I'd love to see someone convert a 4-valve head for use with a 22R series...
Remember that the lower end is a long-stroke motor designed for torque. Piston speeds (RPM) are going to be somewhat limited by the stroke.
Old 06-18-2008, 12:36 PM
BAZ
BAZ's Avatar
Early LS motors are B18a's (90-93), later LS's are b18b's. There is a slight increase in compression and a different intake cam on the B18b's. Building a quality LSVTEC, or CRVTEC motor isnt just throwing a Vtec head on the block of your choice. The B18c's (GSR) have the ports for the oil squirters on the block. These have to be drilled in on the non vtec blocks. One of my buddies has a built-ass b20vtec running 13:1 compression and ITB's and it RIPS! Smokes K20 swapped civics all day.
PS: Some people put H22 heads on H23 blocks, same concept.
A VVT-i Head swap would be sweet for our trucks. Maybe we can snatch one from an is250 or something? haha.
Old 06-18-2008, 01:03 PM
abecedarian's Avatar
a 22re would probably respond well to a 12v setup- 2 intake, 1 exhaust.
delayed opening / faster ramp with a tad more lift on one intake valve and simultaneous closing... swirl and strong intake pulse.... slow ramp up on the exhaust, quick close.
I wonder....
Old 06-18-2008, 06:57 PM
julienade's Avatar
if only...
some underground manufacturer came out with an aftermarket aluminum dohc head for our 22r's and re's
it would be awesome
itbs on a 22r would be awesome too!
Old 06-19-2008, 06:49 AM
bigtrucknwheels's Avatar
Location: Where it always works if you work it, in Sunny Selinsgrove, PA
well, the only problem is you'd have to call it a 22R-FE or if you went with a wide angle valve (more than likely) 22R-GE. that would be absolutely amazing. I myself am looking into a 3VZFE swap. believe it or not, the DOHC setup adds about 40 HP and is a major bump up in fuel economy on the SOHC 3VZE.
Old 08-25-2008, 05:22 PM
escodan760's Avatar
Did you build the 20/22r hybrid yet
Old 08-25-2008, 05:32 PM
escodan760's Avatar
the 20r head will bolt up to earlier blocks with the double row. the pre 85 or 86 block with dome pistons will work. the head will have to be milled down. I'm building one now.
Old 08-25-2008, 06:44 PM
wow sorry about the honda part lol but yeah it will work
Quick Reply: 22r hot rod
