224
id say tahts average. i mean, once i got about 250, but that was all flat freeway driving.. but average city barely will hit 180... it all depends where you live.. im going to seafoam and see how much of a difference it makes. search around if you want better gas milage, but keep in mind... its a 4runner, not a honda civic...
miles on a 7/8 th of a tank is that bad or good
http://www.webwinder.com/wwhtmbin/java_mpg.html
i use that website every time i fill up , i track my mileage every time i refuel, i always remember how many gallons i put in and reset my trip. So last time i got 19 MPG, its kind of fun to see how many mpg you can get,i find myself trying so hard not go past 2K rpm and try to hit every green light.
ive got bfg a/t 32x11.5's and i still manage 22-23 highway.
thats pretty bad. quick math shows around 16.7 mpg. should be able to do atleast 18-19 city unless you're just on the skinny pedal all the time.
Even with the 3.0 I can get almost 20(sometimes) in my 5 speed 4runner. I've driven a 3.0 pickup, and a 22RE pickup, both 5 speeds. I got 24+ with the 22RE, and around 20-21MPG with the 3.0. I've driven an auto pickup with the 22RE, and It got around 21-22MPG. I think you may want to consider a tune up....,.
well i just did oil and air filter before i tested it fuel filter has not been changed in a good 4k is that what could be causing it???
i dont no your gearing but i had stock size tires(p/o put them on) and i went about 320 on a tank with a 22re in my 86 i had and that was city and hiway, just hiway i drove from omaha nebr to davenport ia on 3/4 of a tank and taht was 350miles and i was doin 80-90 half the way
4k? fuel filter should be ok for 100k. when was the last time the o2 got changed? it should be done roughly every 100k on these trucks. plugged cat is also another possibility.
how many miles does it have?
