1995 22rec Scan says "repair Rich"
Old 05-19-2008, 10:25 AM
iselloil's Avatar
Cool 1995 22rec Scan says "repair Rich"
1995 Pickup,4wd,2.4l New engine,injectors,egr,cat converter,cold start switch,all under 3000 miles.When you first start it up and go,there is no power,Get on the interstate and it wont go over 65mph.Snap on scan tool says "repair rich".I've tried new mass air flow,fuel filter,tune up,timing,cleaned the distributor,everything no change.Sometime when you start it up it runs like a scalded cat.ANy Ideas?
Old 05-19-2008, 10:28 AM
Kiroshu's Avatar
All the Timing been looked at?
________________________________________
95 Toyota 4runner SR5 V6 3.0 Automatic 4x4 151,000 Miles
Old 05-19-2008, 10:30 AM
norcalsvx's Avatar
i didnt see o2 sensor on there
Old 05-19-2008, 10:36 AM
Kiroshu's Avatar
Does it feel like its geting gas. Fuel Pump and filter?
_____________________________________________
Old 05-19-2008, 11:19 AM
iselloil's Avatar
Checked the timing,new fuel preesure regulator,new o2 sensor.It feels like its starving for fuel,but i have good fuel pressure.Like today sluggish as all get out,this aftenoon,it runs great.A little hard to start some times.Installed a new cold start injector,and switch.
iselloil's Avatar
Yes,checked timing,used the jumper wire,and set to specs.
Old 05-19-2008, 03:34 PM
84sr5yoty's Avatar
Cold or hot engine?
Does the exhaust expel out any black smoke?
Old 05-19-2008, 03:54 PM
just a 22re's Avatar
like norcalsvx said did try replacing the o2 at all????
Old 05-19-2008, 05:12 PM
iselloil's Avatar
all nex exhaust,o/2,new egr,injectors.Does it hot and cold. Ican restart the engine after it messis up,and the problem goes away.
Old 05-19-2008, 05:27 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Did you get any codes from the ECU....other than the scanner reading?
Old 05-20-2008, 03:17 AM
iselloil's Avatar
no smoke
Old 05-20-2008, 03:18 AM
iselloil's Avatar
The snap on scanner says "repair rich"
Old 05-20-2008, 03:20 AM
iselloil's Avatar
Snap on scanner says repair rich.
Old 05-20-2008, 03:21 AM
iselloil's Avatar
I've not tried to pull from the ECU.I'll try that tonight.
Old 05-20-2008, 08:43 AM
abecedarian's Avatar
When you set the timing, did the idle speed change when inserting the jumper in the diag plug? I ask because some of the symptoms sound like improper timing.
Old 05-20-2008, 09:59 AM
Kiroshu's Avatar
Fuel filter my be clogged or old. It helped mine when i did a month or so ago. It had the factory filter on it. It helped tust me.
______________________________________________
Old 05-20-2008, 04:57 PM
iselloil's Avatar
timing changed
Old 05-20-2008, 04:58 PM
iselloil's Avatar
new fuel filter.regulator,injectors.
Old 05-20-2008, 05:37 PM
I really hate to quote myself but:
timing changed
I hope that wasn't in reply to me. That wasn't what I asked.
Old 05-21-2008, 03:57 AM
iselloil's Avatar
No idle changed
Quick Reply: 1995 22rec Scan says "repair Rich"
