1994 reg. cab only has rear brakes
Old 02-28-2012, 01:08 PM
t_paulson's Avatar
I just picked up a 94 with a 22RE, It only has rear brakes. Could this be caused by the load sensing valve above the rear axle? The rod that connects the valve the the rear axle is broke off from the valve. Or would it be the master cylinder?
Old 02-28-2012, 01:21 PM
abecedarian's Avatar
Not necessarily.
The valve senses pressure from the front brakes and if the front brakes don't have pressure, the valve gives full brake pressure to the rear wheels.
If the rod were broke, and the stub at the LSP-BV were tied up high, it would allow full pressure to the rear brakes.
If the rod stub was allowed to droop, the rear brakes wouldn't get full pressure.
06-01-2021 01:51 PM
Road Bull
10-10-2015 04:55 PM
Nickdigg
07-07-2015 06:04 AM
Steezy96yota
07-06-2015 10:00 AM
elwood73
07-05-2015 07:07 AM
Quick Reply: 1994 reg. cab only has rear brakes
