1993 T100 lower control arm
Old 02-05-2014, 04:46 PM
1995pickup22re's Avatar
Post 1993 T100 lower control arm
I have a 1993 T100 3.0L 2WD with a bent lower control arm, will the lower control arm off my 1995 Toyota Hilux/Pickup 22RE 4WD fit it?
I recently wrecked my father's 93 T100, I slid off the road into a ditch. We pulled it out with his 02 Tacoma, but it didn't want to stay straight on the way home and after looking at it a noticed the passenger side wheel was not facing straight. After jacking it up, the bottom of the wheel was about an in further inward than the top. It was also facing an inch to the right while the driver side is straight. Upon inspection I noticed the control arm is bent and cracked. My 95 pickup is 4 wheel drive while the 93 T100 is two. I read on here that they might have the same independent front suspension components, but I am still unsure. The 95 pickup is definitely not pretty and has 220k miles so I wouldn't feel bad taking parts off it.
Old 02-05-2014, 06:31 PM
buickid's Avatar
I'm almost certain the 2 and 4 wheel drive issue will make them incompatible with each other. You can probably find a control arm on eBay or at a wrecking yard though.
88sasturbotoy
08-11-2015 01:56 AM
Dennisx2
08-04-2015 01:26 PM
kirkrunner
07-27-2015 07:59 PM
ksmudrunner99
07-21-2015 05:33 AM
1994toyota
07-17-2015 03:03 AM
Quick Reply: 1993 T100 lower control arm
