1993 4-Runner 3VZE
Old 09-25-2016, 09:25 AM
ryansawesome1's Avatar
1993 4-Runner 3VZE
I acquired this 4-runner a month or two back now and I haven't had much time to work on it. When I got it, it was lacking power and needed a new timing belt so I went ahead and replaced it. (Not new to that part) After I replaced it, I still felt like I was lacking a substantial amount of power so I got a compression checker and come to find out I only have 30 psi on cylinder 3. What would you guys recommend me check first? The head gasket? Valves? I would generally start with replacing the head gasket, but I'm new to this car so I'm wondering if there's a known thing that goes wrong like maybe the intake valve or something. Thanks.
Old 09-25-2016, 09:59 AM
millball's Avatar
A cylinder leak-down check is in order.
It will likely reveal a burned exhaust valve in cylinder #3.
Old 09-27-2016, 08:59 AM
cbr600rx7's Avatar
Probably carbon build up or a burnt valve if your not having any other issues. A leak down test as suggested would help you pin point if it's valve or cylinder related.
andykrow
09-25-2016 07:42 AM
87truckdude
08-09-2016 09:10 PM
Poppie51
9
07-25-2016 08:39 PM
my924runnerhoodstuck
07-12-2016 01:13 PM
diverdoyle
07-02-2016 06:45 PM
Quick Reply: 1993 4-Runner 3VZE
