Sign in using an external account
| 86-95 Trucks & 4Runners 2nd/3rd gen pickups, and 1st/2nd gen 4Runners with IFS |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
1992 3.0 V6 EFI oil leak
#2 (permalink) |
Personal
Sales Rating: (0)
When you did the clutch, did you change the Engine Rear Main Seal? If so, did you use a Toyota seal? Look underneath the truck, at the transmission bell housing, and find the inspection port (small hole at bottom of housing where it meets the inspection metal plate at the rear of engine) and use your finger to see if there is oil coming out the hole. If so, you more than likely have a rear main leak.
Other oil leaks are usually from the valve covers leaking at the rear of the cover, and / or the rear cam seals that are plastic disks at the back of the head, just underneath the valve covers. An mechanics inspection mirror from the auto parts will enable you to visually inspect this area.
__________________
Bob C Lawrenceville, GA. 2001 Runner 2X 5VZE Auto 129k+ 1993 Runner 4X 3VZE 5spd 182k+ Fire rebuild money pit! 1985 SB 4x 22r(sold) Download the FSM here: http://www.ncttora.com/FSM/ |
| Tags |
| 30, areas, back, efi, front, leak, main, motor, oil, rear, replacement, seal, toyota, v6, yotatech |
