1989 3.ol v6 pickup
Old 04-26-2013, 06:34 AM
fzig's Avatar
1989 3.ol v6 pickup
I, first post 1989 3.ol 4x4 pickup no spark after running about 20-30 mins. when truck dose start CEL works , when truck dies no CEL and no spark from coil replaced ignitor , checked grounds , dist. ohmed ok , did tap test on coil and I get test light flashing on ground side to pos. will set for about an hour and then the CEL (CHECK ENGINE LIGHT) WILL BE BACK ON help...
Old 04-26-2013, 06:36 AM
j2the-e's Avatar
Check the efi fuse terminals. Make sure the fuse fits tight and the terminals are clean.
Old 04-26-2013, 06:42 AM
fzig's Avatar
checked , replaced fuse, ran extra grounds and cleaned mount to coil
Old 04-26-2013, 06:44 AM
j2the-e's Avatar
No check engine light tells me there is a power issue with the ecu. I would start by checking for power and ground at the ecu while the problem is occurring.
Old 04-26-2013, 06:46 AM
fzig's Avatar
efi relay dose get hot when running, can pull fuses when the truck will state and I ear stuff clicking when the cel is not lighting up nothing makes a noise
Old 04-26-2013, 06:53 AM
fzig's Avatar
have power and ground at ecm
Old 04-26-2013, 09:07 AM
fzig's Avatar
new coil,efi relay and ignigter still no start, anyone have a diagram of ecm ?
Old 04-26-2013, 10:28 AM
fzig's Avatar
Ok kids after pinning and testing ecm found no signal from MAF, walked around truck found my best tool ( my hammer) and smacked the MAF / CEL CAME ON ! TRUCK STARTED FEEL DUMB NOW must find MAF the search is on thanks for the help great web site
Old 05-26-2013, 01:48 AM
cginn's Avatar
having similar problem
may sound stupid but I've got a 89 v6 ext cab deluxe with similar problem...what is a "MAF" ?
Old 05-26-2013, 09:27 PM
kuzbro's Avatar
"MAF" Mass Airflow Sensor.
Old 05-26-2013, 11:41 PM
fzig's Avatar
it is part of the air filter cover. it cost about $ 200 from napa with core charge, when you remove it from the cover remember to check the new one out before you leave the store may have to remove the studs from the old one.
Old 05-30-2013, 08:20 AM
cginn's Avatar
Maf
Thanks guys but "been there, done that"... Replaced fuel pump, fuel filter, MAF, 2 Ignitors, plugs wires, rotar button, Entire distributor, TPS. Finally replaced entire engine but problem still remains although not as pronounced...Still need ideas...
Old 05-30-2013, 02:16 PM
j2the-e's Avatar
What are you symptoms?
Alex Bessinger
09-03-2015 12:23 PM
89Yota4x4RatTruck
08-23-2015 04:05 AM
corey519
08-12-2015 11:12 AM
scottyg486
07-19-2015 05:34 PM
Quick Reply: 1989 3.ol v6 pickup
