1986 Toyota Pickup Runs Great but Stalls
Old 04-03-2011, 04:38 PM
craftsman82's Avatar
I have a 86 pickup with a 22R with 81000 miles on it. It was sitting up for about 2 yrs and I am getting it back to life. I have replaced the plugs, plug wires, all carb diaphrams, fuel filter, fuel pump, gas cap. I have also removed all egr and pair valve stuff. I capped everything off. The engine idles great and runs good....EXCEPT it will run for about a mile or two and acts like its running out of gas. It will not rev but it will idle. Let it idle for a min and its good for another mile or two. Its almost like a vapor lock but Im not sure. I find it hard to believe that its a clogged jet in the carb bc it runs perfect for that couple of miles. Any suggestions? Thank
Old 04-03-2011, 04:44 PM
xxxtreme22r's Avatar
you low on fuel, is it old fuel? Check to make sure you didn't mix up the two fuel lines, supply and return.
Also could be vacuum leak caused by an opening vacuum switching valve that is based on temp and isn't either caped or routed properly.
Old 04-03-2011, 07:02 PM
It has over a half a tank of fuel, fresh fuel too. Also it was doing this before I started taking the vaccum stuff off. Talking to some local friends, we are thinkin that the tank needs a cleaning/draining. Possibly there is some trash blocking the pickup tubes.
DacodaYota
09-02-2015 02:13 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
Dylan199119
06-25-2015 09:54 PM
dirtrider0129
10
06-24-2015 12:24 PM
paxanders
06-21-2015 06:29 AM
Quick Reply: 1986 Toyota Pickup Runs Great but Stalls
