1986 clutch pedal problem
Old 10-01-2009, 09:13 PM
Bulldog's Avatar
Question 1986 clutch pedal problem
hello, i just installed a new clutch, throw out barring, and pressure plat in my 86 toy. About 1 1/2 months ago i replaced the clutch slave cylinder. Since i replaced the clutch yesterday, for some reason after the truck sets for awhile, the clutch pedal seems to bleed itsself down. When i start to go anywhere i have to pump the clutch pedal a few times to get a good pedal. Ive bleed the pedal but it didnt seem to help. Has anyone had this problem? Does anyone have any suggestions on how to fix this problem?
Old 10-01-2009, 09:17 PM
turboboost's Avatar
Clutch master cyl or a leak someone. It's also possible your slave may have gone bad again.
Old 10-01-2009, 10:15 PM
thadlinkwent's Avatar
Do you notice fluid going anywhere?
My clutch master was leakin inside.
Old 10-01-2009, 10:25 PM
Bulldog's Avatar
no. i looked all around the slave cylinder and followed the lines up to the master cylinder and didnt see anything leaking anywhere.
Old 10-01-2009, 10:27 PM
When my brake master went out it didn't leak. just no pressure until 4 quick and hard pumps.
Old 10-01-2009, 11:03 PM
turboboost's Avatar
Could be an internal leak. I'd just replace the MC, they are cheap.
smthwsn357
12-04-2023 02:08 AM
the1998sr5
15
07-14-2020 08:35 PM
mskalmus
05-28-2017 07:51 AM
Kalihi,HI
07-09-2015 04:29 PM
karbin
07-05-2015 11:37 PM
Quick Reply: 1986 clutch pedal problem
