1986 22re bubbles coming from radiator.
Old 09-02-2017, 12:31 PM
  #41
ksti's Avatar
LOL!
Old 09-02-2017, 12:55 PM
  #42
ksti's Avatar
Okay, Okay, all kidding aside, did you get your radiator back and you should be done today?
Old 09-02-2017, 01:01 PM
  #43
DMcGarigal's Avatar
anyone got a part number on the BVSV?
Old 09-02-2017, 01:06 PM
  #44
DMcGarigal's Avatar
not back yet, probably looking at tuesday, or wednesday, because of labor day, but that gives me time to find this darn valve..
Old 09-02-2017, 01:15 PM
  #45
ksti's Avatar
Old 09-02-2017, 01:19 PM
  #46
DMcGarigal's Avatar
doesnt look the same, hmm.. I've found ones that look the same but say they are for an 87+ or an 86 with 4wd, or basically every combo except what i've got. Does it really make a difference?
Old 09-02-2017, 02:08 PM
  #47
ksti's Avatar
Can you post up a pic as to what it should look like?
Old 09-02-2017, 05:18 PM
  #48
DMcGarigal's Avatar
the one in the middle of rad's post a few back
Old 09-02-2017, 06:45 PM
  #49
old87yota's Avatar
You can try 22RE Performance. https://22reperformance.com/intake-e...witching-valve
According to their website, the black BVSV for 22R-E engines should fit all years 1984-1995. It is spendy though at $90.65, but it will be a brand new Toyota part. (you have to select "1984-1995 22R/22RE" Black the drop-down menu for the price of that valve/ switch to show up)
You can call them to confirm fitment.
Old 09-02-2017, 07:22 PM
  #50
DMcGarigal's Avatar
Was just looking at their site, planning on calling asap
Old 09-03-2017, 11:05 AM
  #51
DMcGarigal's Avatar
My mind has been working overtime waiting for my rad to get back and i havent been able to stop researching issues associated with the EGR ahah. Ive got a great theory going in my head right now all stemming from that broken bvsv. When the engine gets up to operating temps that bvsv should allow vacuum through it, to open the EGR, to allow exhaust gas to flow through the intake into the cylinders, which in turn reduces NOx, AND lowers the combustion temperature and power lost in the form of heat to the cylinder walls. With that valve broken, the EGR doesnt open after the engine is warm. (the EGR is also only open when you're on the throttle i believe) without the recirculation of gas, the combustion temperatures are super heating the cylinders, causing flash off in the coolant jackets of the engine. This coupled with even a semi clogged radiator could be my issue..... Is it wednesday yet?
Old 09-03-2017, 11:10 AM
  #52
millball's Avatar
I didn't re-read the whole thread to see all your efforts, but I'll throw this out anyway.
Improper ignition timing can result in excess heat being rejected to the coolant.
Old 09-03-2017, 05:06 PM
  #53
DMcGarigal's Avatar
I think thats basically what im getting at with a stuck closed EGR, right? not recirculating the exhaust gas causes an early ignition.
I haven't heard the pinging though, what are the chances that the bad bvsv could have causes internal engine damage? Idk when it broke so i cant say for how long its been broken, the engine still runs like a dream though, idles nice and smooth, and cruises pretty good on the highway still (minus the running hot). At this point im just worried other damage could have been being done... Or is it more of a "if i fix it before other symptoms arise dont worry about it" kind of deal?
Old 09-03-2017, 07:11 PM
  #54
millball's Avatar
Pinging is usually the result of over advanced timing .
Retarded timing can also cause inefficiency that will throw excess heat to the cooling system, but no pinging will occur.
Not likely there is internal damage from inop EGR, but best to restore to correct operation soonest.
Old 09-03-2017, 07:56 PM
  #55
DMcGarigal's Avatar
Thanks millball, maybe ill actually sleep tonight lol
Old 09-04-2017, 12:24 AM
  #56
Kolton5543's Avatar
I think your in the wrong track with the egr. Egr should only be open during cruising speeds at operating temp with the throttle just cracked open. It can lower the combustion chamber temps but not to a significant enough amount. From what I read, you seem to be having your problem mainly at a stand still while egr wouldn't do anything at all. I think your problem has to deal with a clogged cooling system or a bad water pump. I'm betting pretty good on a pump. I've seen a lot of them where the impeller will corrode off to almost nothing or separate from the shaft causing them to move a little coolant at high rpm and none at low rpm. I believe the bubbles you see is non flowing coolant boiling in hot spots of the engine. You said there was some belt squeal some times but the tension and belts were good. Remove the water pump belt and check for any play in the shaft and how difficult it is to turn. It should be pretty effortless if there's any play in the shaft or is hard to turn it needs replaced. It may be worth it to just take it off and inspect the impeller and the condition of the coolant passages to it.
Old 09-04-2017, 06:48 AM
  #57
DMcGarigal's Avatar
When I had the belts off I was able to spin the water pump, no bearing flat spots, and no play, nice and smooth. To clarify, if I start the truck in my driveway and don't drive it at all, it will not bubble over, I've only ever noticed it bubble over after driving at cruising speed, and then coming to a stop, where it then begins to bubble. If I sat in stop and go traffic for three days straight it wouldn't bubble, it's only after getting up to speed and cruising around 45 mph for a significant amount of time. The pump also looks non-original, as in it's been replaced once already by a P.O. I definitely do notice some brown scaling on the coolant passages which you can see in the attached pictures hopefully. And I also have pictures of the bvsv part number. Bvsv and part number
Looks like mud, but isnt goopy. Stuck on there pretty good.
Old 09-06-2017, 10:38 AM
  #58
DMcGarigal's Avatar
radiator was bad, got it back today, shop said it was pretty muddy and clogged up, ordered a new CSF 2314, and a few other parts... now i wait
