Wire Harness Help - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-09-2009, 08:38 AM   #1 (permalink)
Spookee's Avatar
Wire Harness Help
I am building a 1985 xtra cab 4x4. My plan was to use a factory turbo system on the 22re however after reading about others experiences I am not putting the turbo on. I have the wire harness and the ECU for a 1987 4x4 truck and would like to use them for the EFI system for the 1985 22re.
Can I use the turbo harness, ECU and gauge cluster without the turbo?
Spookee is offline
Old 11-09-2009, 03:43 PM   #2 (permalink)
I had a 86 turbo truck that i put a 88 model motor in . both trucks where efi ,i used the turbo truck ecu ,injectors, wiring harness. the 88 had diffrent injectors. the turbo light still came on like when it had one. the only problem i had was it was higher geared ,which caused it to be a gutless wonder on hills.
swampfox is online now
Old 11-09-2009, 04:38 PM   #3 (permalink)
Spookee's Avatar
Gearing should not be a problem. The only thing turbo will be the harness and ECU and gauge cluster.
Thank you for your input.
Spookee is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2009 InternetBrands, Inc.
