Whats the best performance mod?
get a header need a new hi flow cat, 2.25 pipe, glasspack, intake, 8mm plug wires, cam shaft, valves, ignition box, polish/port, electric fan ....
And when its all said and done all you need is tires, gears, lockers, crawler box, bumpers, sliders, winch, straps, cb...
Once you start its hard to stop.
what i really wanna do is put a 340 cfm edelbrock carb, rear locker, msd ignition, longtube header, flowmaster exhaust, oversized stainless steel valves, cam it, and put some 31x12.50 tires on it with some nice wheels....o and paint it all white
expensive list i know
thats never a bad thing...if i had the income then my truck would definitly have one of them lcengineering motors in it...one of the turboed ones
Power gains for cheap are minimal at best. Get your truck working so that it's at 100% and then go drive it.
The best gains can be had by modifying the nut behind the wheel.
If you want to go racing, go buy a corvette. If you want to go 'wheeling, do tires, lockers, armour, and then a winch.
Part Description: Top End Kit(Pro) - 22R/Carb. P/U & 4Runner (85-95)
Price:
$2,499.95
More Information
22R Pro Top End Kit - P/U & 4Runner (85-95) Carb
The key to really improving the performance of your Toyota 4 cylinder engine lies with the Top End. Meaning, the carburetion, cylinder head and exhaust header. LCE has assembled some new kits with matched components to give you some proven performance for just about any application. LC Engineering's Top End Kits include, 22R Street Cylinder Head, Weber 38 Carburetor Kit, LC Engineering 1 1/2" Street Header Kit, LCE Pro Distributor, LCE Powder Coated Valve Cover, Street Performer Camshaft, Viton Valve Seals and Rocker Arms.
Price:
$2,499.95
More Information
i'd do a weber 38mm carb, and headers that should help. if your still power hungry i would suggest getting used to it but you could do a cam and a 4 barrel carb, then you will want an msd ignition system.
ive just learned to deal with the gutlessness and give it enough traction and flex to make up for the power
