Water coming out of exaust... Bad?
Old 04-22-2008, 01:28 AM
stormin94's Avatar
Originally Posted by DATTOY
I just did a tune up and there was no broken ceramic. It's getting progressively worse though. I have to put more and more water in. And the other day at start up a lot came out at the header, but i haven't had much time to get in there.
Change your oil, and see if it looks like a milk shake, like if water got in there. I've seen strange things happen if the timing chain gets neglected for too long. It likes to eat through the water pump, and then sometimes into the block, so you might be getting that too, unless you know for a fact that your timing chain has been replaced recently, I'd check that just to be sure, because you are naming all of the symptoms the customer who brought in his 22RE truck named, and he suspected a failing head gasket also.
Old 04-22-2008, 10:25 AM
DATTOY's Avatar
When i bought the truck 3 months ago, the guy said it was a new motor with 80,000 miles on it, along with the tranny. But no receipts. I check my oil almost every other day, because of the fear of a head gasket going out.
Is it normal for a head gasket to go after 80, on an 84?
Old 04-22-2008, 07:05 PM
stormin94's Avatar
It's not normal for a head gasket to blow anyway.
Old 04-22-2008, 08:52 PM
rowdy235's Avatar
If you're referring to the engines reputation, the 22r is not particularly known for blowing head gaskets; though it does happen.
Old 12-07-2008, 01:33 PM
  #25
King of Crown Town's Avatar
Originally Posted by eric-the-red
If you were burning coolant there would be white smoke and a sweet smell, and most obvious the level in the rad would be dropping. Water dripping from the tailpipe at idle is normal. With the engine idling the exhaust system doesn't get hot enough to keep it vapourized and some condenses in the pipe.
Great answer! You put my mind at ease! I was topping off the tranny fluid and had the truck idling while doing so. When I was done, I notice some water on the ground next to the muffler end. Your answer explained exactly what was happening. Thanks!
All that head gasket talk was freaking me out! The HG got replaced 50k ago!
Old 12-07-2008, 04:13 PM
  #26
abecedarian's Avatar
Some water dripping from the tailpipe is absolutely normal on cold starts. It could be enough to make a wet spot on the ground a foot or more in diameter. If it's cold enough outside, you might also get some steam along with it.
As mentioned, one of the byproducts of burning fuel is H2O. The fact that the exhaust system is cold due to it being cold outside, causes the H2O vapor to condense on the pipe and eventually puddle enough in the muffler to get blown out the tailpipe. It should however stop once the exhaust has warmed up, the O2 sensor is functioning and the choke (on carb'd vehicles) has pulled off or (with efi) the coolant temp has warmed up enough to let the ECU go into normal operation.
If you're getting water dripping from the tailpipe after the engine has fully warmed up it's either that it's cold outside and the exhaust pipe behind the converter is cold enough to cause the water vapor to condense, or the fuel mixture is too rich, or the headgasket is in fact blown. Depending on the severity of the head gasket breech, you may or may not get the characteristic white smoke associated with a blown headgasket. However, if it is the headgasket, the exhaust will have a 'sweet' smell, not entirely unlike burning corn or maple syrup.
If fuel or oil is getting into the cooling system, you should see a rainbow-like film on top of the coolant when you open the radiator (do it cold!).
If you open the radiator cap and start the engine when cold, if you see bubbles in the radiator, it's likely the headgasket has blown. Also, the spark plug in the affected cylinder(s) will be noticibly cleaner than the others.
icentropy
09-16-2020 02:47 PM
Eggslinger
06-08-2019 03:32 PM
09-04-2015 09:27 AM
smiley52
07-11-2015 05:16 AM
jakebarrett
07-10-2015 07:15 PM
Quick Reply: Water coming out of exaust... Bad?
