Steering "issue" - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-15-2009, 01:22 PM   #1 (permalink)
g_cali's Avatar
Steering "issue"
So yesterday i got my 4runner stuck pretty bad. Now when im driving straight down the road my steering wheel is upside down. I checked it out, nothing looks visibly bent...what did i do?
__________________
85 4runner 22re 5spd, 4" national spring lift/shackles, 35's, 4.88's,
advanced adapters 4.7 t-case gears, tru-trac rear, lock rite front, sliders, diff breathers
-- now waiting for hysteer --
86 4runner 22re 5spd, stock
g_cali is offline
Old 10-18-2009, 03:28 PM   #2 (permalink)
my-4x4's Avatar
Take off steering wheel and turn it 180 degrees. To get to it remove your horn (should be a screw maybe two on the bottom) I believe it slides up (towards normal top position) and then remove the center nut holding the steering wheel, and rotate.
__________________
-'87 4x4 22r fairly stock.
-Thrush glasspack
-Hurculined cab floor
-SR5 Gauge swap
-'84 4x4 22r STOCK
-32x11.5 BFG M/T
-Magnaflow exhaust
USAF Confinement Officer
my-4x4 is offline
Old 10-19-2009, 09:44 AM   #3 (permalink)
Etype R's Avatar
Sounds like something slipped, time for high steer?
I bent my tie rod pretty good last time I was out wheeling, for me its time to ditch the stock push/pull steering setup and convert to high steer. Just ordered up everything I need for the swap last night
__________________
1985 Toyota 4Runner - Full SR5 package - 4 inch lift - 35" tires
Etype R is offline
Old 10-19-2009, 10:18 AM   #4 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
Sounds to me like you bent something. If it's not pulling, then probably the drag link.
__________________
Quote:
Originally Posted by Junkers88 View Post
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 10-19-2009, 11:06 AM   #5 (permalink)
g_cali's Avatar
Yeah im plannin on high steer down the road, just don't have the money right now
__________________
g_cali is offline
Old 10-19-2009, 11:29 AM   #6 (permalink)
grant526's Avatar
Are then ends of your drag link parallel?
Is there excessive play in the wheel?
I Wedged myself last year on the Rubicon and broke my stock steering. It both bent the J-arm and shatted the coupling between the J-arm and the Drag link.
Have you jacked the front of the truck up and played with the steering, turing the wheels by hand? You'll have to have the steering column unlocked to do so.
After breaking mine, i converted to crossover steering and couldn't be happier!! : ) But I also added Power Steering while I was at it.
Good Luck with it
BTW Great Lookin' Runner!!
__________________
'85 Standard Cab
4.5" HD SuperLift
Custom Winch bumper
33x12.50 Mud Rovers
Lincoln Locked in the rear; running 5.29s
DD's: '87 XJ and '91 Suzuki DR650s
Wheel Responsibly, Don't screw it up for the rest of Us. . .
"Obama is an acronym.
OBAMA = One Big Ass Mistake, America" - Thanks for the Quote Hayes
grant526 is offline
Old 10-19-2009, 11:35 AM   #7 (permalink)
g_cali's Avatar
My dad should be coming over later to help me with it, steering is one thing ive never really delt with. But yeah i found a hi-steer kit an ifs box on craigslist, but i don't have the money right now. Thanks for the compliment, its an awesome rig
__________________
g_cali is offline
Old 10-19-2009, 11:45 AM   #8 (permalink)
grant526's Avatar
It's not the cheapest setup out there, but i like the www.4x4labs.com crossover setup. Check it out, it moves the tie rod behind the axle. I don't have any experience with it, but someone showed me the website a while back and I like the concept a lot.
Keep us posted as to what's the issue and how you resolve it. : )
__________________
'85 Standard Cab
4.5" HD SuperLift
Custom Winch bumper
33x12.50 Mud Rovers
grant526 is offline
Old 10-19-2009, 01:15 PM   #9 (permalink)
Etype R's Avatar
See if you can barrow the money to buy the hi-steer setup. Its a much safer system and will hold up better on the trail. And with your stock setup giving you problems, its the perfect time to upgrade
__________________
Etype R is offline
Old 10-19-2009, 01:54 PM   #10 (permalink)
grant526's Avatar
If that's an option, I would Definitely Jump on it! Just keep in mind that you'll have to purchase an IFS Steering box also. Be it rebuilt, new or used. I went the Used route and also got the Power steering pump with all the mounting hardware for the same price that I found just a rebuilt box for. But I assume you have PS, so it'll be cheaper just to pick up a used steering box.
Steering is one of the most important components of a vehicle. You need it to work, be safe and Reliable at all times!!
Good Luck!
__________________
'85 Standard Cab
4.5" HD SuperLift
Custom Winch bumper
33x12.50 Mud Rovers
grant526 is offline
Old 10-19-2009, 02:21 PM   #11 (permalink)
g_cali's Avatar
Well hopefully in the next few weeks I'l be able to sell my 86 4runner an have some money to put into the 85...
__________________
g_cali is offline
Tags
1985, 4runner, 4x4, 85, right, runner, steering, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
