Replacing 85 t-case output seal. No crush sleeve or bearing preload issues?
Old 10-18-2016, 10:01 AM
advlars's Avatar
Hey guys,
Ive read through a couple of forums and looked at the FSM, but im still scared of messing with my t-case.
Just want to confirm that if I pull off my transfercase output flanges to replace my output seals, there are no crush sleeves (like you would find in a differential) or anything else that would effect bearing preload? Just crank the nut back to 90lbs and call it a day?
Specifically I need to do the rear output seal, but Id like to know about the front output seal too. Might do them both if its easy.
Cheers
Old 10-18-2016, 11:11 AM
millball's Avatar
No crush-sleeve issues.
Torque to 90-95fp and you're golden.
Front output is the same except for the existance of a pressed in steel retainer and heavy felt protector in front of the seal.
Drain the case before you mess with the front output, to avoid an oil mess.
128keaton
08-07-2016 08:40 AM
Rory Jackson
08-01-2016 04:02 PM
msugoose
07-28-2016 04:23 PM
John Turpen
07-27-2016 11:10 PM
95_n130
07-20-2016 11:12 PM
Quick Reply: Replacing 85 t-case output seal. No crush sleeve or bearing preload issues?
