Need help with brakes
Old 07-03-2008, 05:07 AM
tacdeg's Avatar
Unhappy Need help with brakes
I need help with my brakes. i have a 85 pickup. i changed the front pads. when i did the brake line broke where it hooks up to the caliper. When i put it back I cannot get any pedal at all. I tried to bleed the front brakes but still have no pedal at all.
Thanks tacdeg
Old 07-03-2008, 05:13 AM
plumo57's Avatar
can we assume you replaced the brake line? Not trying to insult, just to get full info. Is there any fluid leaking at that caliper?
Old 07-03-2008, 05:36 AM
Swansen's Avatar
well, its generally just a good idea to bleed the brakes completely whenever you remove any lines, so some air might have gotten into your rear lines, so bleed everything, rear and fronts.
1uzRunner
63
11-10-2018 03:58 PM
old87yota
09-09-2015 12:39 PM
fabing455
09-07-2015 08:08 AM
Scatterbrain
09-03-2015 06:46 PM
Quick Reply: Need help with brakes
