YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-23-2007, 05:55 PM   #1 (permalink)
limited slip
How would I be able to tell if my 85 SR5 truck came with a limited slip from the factory. I really don't wanna tear it open to use in my 88 if there is not one. I know on GM there is a sticker in the glove box. Does toyota have anything like that? Thanks Bill
onefast66nova is offline
Sponsored Links
To remove this ad, register today!
Old 08-23-2007, 09:09 PM   #2 (permalink)
deserttoy84's Avatar
Send a message via AIM to deserttoy84
i dont think lsd was even an option back then. Unless someone did a swap then its prob open. Just jack up the rear end and spin one of the tires. If the other tires spins the opposite direction then its open.
__________________
1984 toyota sr5 4x4
22r w/ weber 32/36
Pro comp 4" front springs and 3" rear downey springs
D-tech Shocks
33x12.5 M/T , 15 inch weld rims
Hella 550/ Hella h4 conversions with HID
Home made On-board air system
deserttoy84 is offline
Old 08-25-2007, 08:45 AM   #3 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
No LSD or any kind of traction device in the USA from the factory.
Adam F is offline
Old 08-25-2007, 04:58 PM   #4 (permalink)
slacker's Avatar
Yep .. no LSD's in the trucks from the factory . common aftermarket install in the early years . Posi you can confirm with the wheels up .. LSD you can not .
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come .
84 2WD "hotrod" Intercooled 7MGTE
83 Trekker SR5
MY PAGE
2WD fourm I frequent
NEW Trekker forum
slacker is offline
Old 08-25-2007, 05:00 PM   #5 (permalink)
stormin94's Avatar
When in doubt, do a burn out!!! Just put one tire in the gravel, and one on the road, and see if just the one spins. If it does, congratulations, you have an open diff
__________________
1994 Toyota 4Runner SR5 4X4
208,000 miles and counting
3.0 V6, 5 speed
14/19 MPG city/hwy(before 33's)
Current Mods
Headers, 2.5" Flowmaster custom exhaust, K&N FIPK
KC Daylighter 100 Watt lights
Ranchos x4, 2" Lift Downey coils
33-12.50 M/T's, 1" t-bar lift, 1" body lift
Tow pkg w/ lighthookups
Silverstar Headlights, Pioneer Deck w/XM
Brushguard
250Watt JLAudio 8" W3 Sub
Future Mods
12V Aux outlet-400/800peak inverter
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
stormin94 is offline
Old 08-25-2007, 06:52 PM   #6 (permalink)
Well that is what I was thinking.... It is in my parts truck and I was hoping to get lucky and it have one for my good one but, it does not! Thats just my luck
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Limited slip for 4Runner GREEN4SKIN'R 95.5-2004 Tacomas & 96-2002 4Runners 3 06-03-2006 09:53 PM
Limited slip in my Tacoma? nags 95.5-2004 Tacomas & 96-2002 4Runners 36 06-05-2004 11:16 PM
stock limited slip? livelarg 95.5-2004 Tacomas & 96-2002 4Runners 3 07-30-2003 05:19 PM
What are my limited slip options? Los Gatos? 95.5-2004 Tacomas & 96-2002 4Runners 3 03-02-2003 08:45 AM
TRD Limited Slip AndersBr 95.5-2004 Tacomas & 96-2002 4Runners 0 08-24-2002 07:01 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
