getting hard to shift
Old 03-10-2006, 08:14 AM
deserttoy84's Avatar
on my 84 toyta 22r 5 speed its seems like 1,2,3 gear are hard to shift into. simetimes it like wont go into 2nd. im thinking the syncros in the tranny are starting to give out... how much do shops charge to replace em usually? o yea the clutch is pretty new too.
Old 03-10-2006, 08:51 AM
mike_d's Avatar
first check to see if it's not the shifter bushing, that's an easy and cheap fix:
http://www.off-road.com/toyota/tech/shifter/index.html
cheap solution #2: learn to double clutch. my syncros are starting to wear on my 5 speed. it has 250,000 miles on it and it's never been rebuilt or anything, so i can believe that the syncros are going bad. i'm cheap, so when it gets hard to put it in gear i just double clutch an all works well.
Old 03-10-2006, 11:59 AM
4Mogger's Avatar
change the fluid out and replace with Redline MTL. This will at the very least help, and may actually "fix" your issues.
Liadrin
04-25-2022 02:54 PM
rusty904
03-27-2017 05:20 PM
Liadrin
09-01-2015 06:44 AM
JAmdor3
08-11-2015 10:53 AM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: getting hard to shift
