engine swap
engine swap
what is a common semi-easy engine swap for my 85? besides a chevy 350. id like a little more power but i also would like to stay as light as possible and not have to worry about getting custom front springs and i would like to keep the yota trans and t case.
There is not such thing as an easy engine swap. If you want to stay around the same weight I think your best option is a 2RZ or 3RZ out of a Tacoma. You have to use a different transmission but you can adapt to your case(s). Not easy, but no engine swap is.
hhmmm is the 85 different then an 86.. i thought the 2rz bolted to the stock trans and pretty much bolted in so to say...
help me out please.. im 18 and i have the 2rz stock nd i wanna put it in thanks man =]
steve miller
10-10-2015 01:40 AM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
