85 EFI to Carb conversion-Harness issues
Old 05-27-2010, 12:47 AM
tyler_1990's Avatar
hey yall i need some assistance i have a 84 carbed pickup i took the engine out and put it in a 85 efi 4 runner after many hours of frustration getting the efi to work i said screw it and went back to carb i put a weber 32/36 on it runs grrreeeat. since the carb is now in the efi runner i want to clean up all the un needed stuff in the engine compartment and get my water temp gauge/fuel gauge working, is it possible to get the harness out of the 84 p/u (i have everything) and get it into the runner
yes i have searched but could not find anything to help out to amount to anything
Old 05-27-2010, 01:08 AM
drew303's Avatar
The fuel tank float unit should be the same it think? Maybe not, EFI has the pump IN the tank and carb has a mech on the motor.. so maybe how they measure fuel capacity IS different?
but to answer your q yea u can swap harness's, have fun tho, thats a lot of work
what was wrong with the EFI?
Old 05-27-2010, 01:20 AM
tyler_1990's Avatar
i got all the fuel delivery stuff figured out, if i decide to keep my harness cant i just modify the efi sensor to work with the sensor on the carb intake and get rid of all the crap cluttering it up under the hood
also my freaking fuel gauge aint working only got about .50 volts at the sender plug
Old 05-27-2010, 11:58 PM
tyler_1990's Avatar
i couldnt get the injectors to fire they only fired once and that was it lol and i dont have a lot of money to get new fuel inj parts
Old 05-28-2010, 01:06 AM
tyler_1990's Avatar
my gas gauge is going to full no matter what has anyone had this issue and what was the fix
Old 06-11-2010, 01:23 PM
twhite's Avatar
Did you have to change the distributor, coil and ignitor when you converted it to carb from EFI?
Old 01-25-2011, 04:57 PM
kylesiarkowski's Avatar
im converting my truck from carb to efi. do you guys have any tips?
and how hard is it to be done?
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
tomczaksdiesel
07-26-2015 10:35 PM
toofly1999
07-25-2015 07:09 PM
Yota.Jay
07-23-2015 08:08 PM
Quick Reply: 85 EFI to Carb conversion-Harness issues
