85 22RE MSD Ignition
Old 06-20-2009, 10:45 AM
nevadamatt71's Avatar
Are the NGK plugs still the best or is there something new I should be using?
I would like to change to MSD ignition but is it worth the money?
Old 06-21-2009, 02:35 PM
myyota's Avatar
There is really no need to change the stock ignition system over to MSD, the stock ignition system on a 22RE is actually a good set up, with the only expensive part being the ignitor it self. I you want to upgrade the stock ignition then get a higher output coil and some good quality wires. For spark plugs use NGK or Denso, they seem to work the best. In my opinion the only time you really need to up grade the ignition system is if you have a built motor and are looking to get everything out of it.
Old 06-21-2009, 02:48 PM
BigBluePile's Avatar
x2, I had a Crane HI-6s on mine and the truck actually ran BETTER with the OEM ignition.
I'm using a Crane Fireball coil and Accel 8mm wires with NGK plugs.
MO transplant
04-23-2023 11:58 AM
Sleaker
08-26-2020 06:03 AM
80Truck
07-24-2015 03:12 PM
nickb3
07-21-2015 10:00 AM
94whiterunner
07-12-2015 07:15 PM
Quick Reply: 85 22RE MSD Ignition
