YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-19-2008, 12:45 AM   #1 (permalink)
rookieyota's Avatar
5.71 gears!
Total noob question.. but what's an estimated price range for droppin 5.71 gears in an '85 3.slow 4runner 4x4? ... or how hard is it to install gears yourself?
rookieyota is offline
Sponsored Links
To remove this ad, register today!
Old 08-19-2008, 12:49 AM   #2 (permalink)
misto's Avatar
did u swap a 3.0?
__________________
'85 Runner
misto is offline
Old 08-19-2008, 12:53 AM   #3 (permalink)
rookieyota's Avatar
nah P.O. did for who knows what reason.. cant afford a swap for a good while so i thought id make the best of it..re gearing would do me a lot of good.. any takers for my original question?
Old 08-19-2008, 01:12 AM   #4 (permalink)
Jeenyus04's Avatar
5.71 are supposed to be a little weak because of how small the pinion is so if you are doing any off roading you may wanna just go with 5.29's As far as the install I'm not sure though you can buy complete thirds set up with new gears from trail-gear, marlin crawler, or allpro. If your not pretty comfortable with mechanics and tools and such I wouldn't suggest doing them yourself.
Just my .02
__________________
85 reg cab s/b, rebuilt 22r, .040 over bore, engnbldr's crawler cam, no cat w/ flo-pro (was on it). tg 5 inch lift. 35 baja claws bright green paint, sliders, custom front bumper, miller rear locker --project--
02 dodge extended cab s/b, black sport, 24 vavle cummins, 35's, 4 inch exhaust, edge ez
Jeenyus04 is offline
Old 08-19-2008, 02:32 AM   #5 (permalink)
muddpigg's Avatar
http://www.gearinstalls.com/
muddpigg is online now
Old 08-19-2008, 12:03 PM   #6 (permalink)
rookieyota's Avatar
thanks for all the info so far..
Old 08-19-2008, 12:33 PM   #7 (permalink)
Check out marlin, or allpro.
OR
Randys ring and pinion
Those will be the price for the gears.
Call your local shops to verify for the install prices, because it varies
__________________
1990 4runner SR5, 3.0 with 254K, 5-speed, 4.56 gears, , Rancho 9000's, 33X12.50's trxus mt's, rear lock right, 4" lift with lc coils in rear
Quote:
Originally Posted by 4rnr View Post
I have NOOO $$ Im a poor college kid I recently started working so I decided to SAS.
If I dont sas Ill just waste money on chili cheese dogs and beer then Ill be poor, fat, and STILL on ifs.
My build thread
http://www.yotatech.com/f152/904_run...thread-158746/
904_runner is online now
Old 08-19-2008, 02:08 PM   #8 (permalink)
jmazoso's Avatar
Cheak out East Coast Gear Supply
http://eastcoastgearsupply.com/
Chase has great service, and awesome prices.
__________________
Trail Truck: 84 regular cab 85 22r -- streetRV head, 261C cam, 2.5" flowmaster, lock-right in rear, 1" Wabfab BL, IFS brakes, rock sliders, diff breathers, Amsoil, dual cases, front rock lights, tube bumper, 33x12.50 BFG MTs, 213k miles
---Currently: 5.29 prescion gears, cryo'd (just need to get them installed) send money
---Next: Front bumper
Link to build-up: http://www.yotatech.com/f115/jmazoso...uildup-137611/
DD: 01 Tundra V8, 3" flowmaster, FIPK, 120K miles
jmazoso is offline
Old 08-19-2008, 03:14 PM   #9 (permalink)
rookieyota's Avatar
thanks for all your help guys..
this is what i need right? .. for rear--->http://www.ringpinion.com/ProductDet...px?ProdID=4902
for front--->http://www.ringpinion.com/ProductDet...px?ProdID=1124
also.. 5.29's are good to have with a 10" lift and 37" tires right?
Old 08-19-2008, 03:30 PM   #10 (permalink)
rookieyota's Avatar
Old 08-19-2008, 03:53 PM   #11 (permalink)
ryantowry_81's Avatar
you said 85 4runner? the ring and pinion you showed was for an IFS front, isn't yours strait axle? if it is strait it will be an 8" ring gear.
I have done gears but only with my dad who has been doing them for twenty years. i would not recomend a gear install yourself unless you have some one to show you/ coach you through it. it is a good skill to learn though!
__________________
the "Turtle":
goes really slow but always gets there in the end!
84 ex cab
63" chevies
Rears Up Front
Square Drive Shaft
Trail Gear Cross over
aussie locker
39.5x15-15 TSL's
295k on motor, new Buick V-6 motor on the way!!!
Denali offroad club:
http://www.denalioffroadclub.com/for...orum/index.php
ryantowry_81 is offline
Old 08-19-2008, 05:38 PM   #12 (permalink)
vtjeenyus's Avatar
but if you are still interested in doin it yourself i think that randys ring and pinion sells a how to video but its really not that hard if you have access to a press
good luck
vtjeenyus is offline
Old 08-19-2008, 06:45 PM   #13 (permalink)
netwt12's Avatar
i assume it only has the factory t-case. i run 4.88s in mine but i have two cases. i think you'd be fine with 5.29s and the 3.0.
__________________
2000 4Runner Limited 4x4 "TRD". Blown, etc.
1988 Trail Truck. SAS, Dual Cases, Exoed, Aluminum Trail-Ready Beadlocks, 37" Boggers, and Extreme Rock Rash.
2008 Camry LE.
netwt12 is offline
Old 08-19-2008, 06:49 PM   #14 (permalink)
netwt12's Avatar
you need 2 of these
http://www.ringpinion.com/ProductDet...px?ProdID=1318
__________________
2008 Camry LE.
netwt12 is offline
Old 08-19-2008, 06:53 PM   #15 (permalink)
netwt12's Avatar
you also need 2 setup kits for an 8" 4cyl. diff
http://www.trail-gear.com/toy-diff-setup.html
__________________
2008 Camry LE.
netwt12 is offline
Old 08-20-2008, 02:13 PM   #16 (permalink)
AZ4ME's Avatar
There is nothing wrong with 5.71 gears. I run them on my 88 4runner (85 front axle). The key is making sure they are setup correctly. Most people I know uses ZUK (gearinstalls.com) cause he's the Toyota diff guy. You can get the cryo'd 5.71 gears from him also. If you are looking for this to be done ASAP, then ZUK won't be your guy. He closes up shop in the summer (too hot). Probably won't be open again until October. Just make sure whomever you use, really knows what they are doing if you go with 5.71's.
__________________
-Brian
'88 4Runner
'00 4Runner
AZ4ME is offline
Old 08-20-2008, 02:27 PM   #17 (permalink)
Jay351's Avatar
Send a message via MSN to Jay351
Good posting^
The bigger the R&P the more important a good install is.
__________________
91 Pickup - xcab - 5sp - 3.0 - sr5 - 4x4 - 230,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs |Diff breather mod | Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic
http://www.cardomain.com/ride/2572486
Jay351 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
gears????? racingcameron66 General Vehicle Related Topics (Non Year Related) 38 03-17-2008 09:49 AM
WTB 7.5 4.88 gears, V6 rear 4.88 gears, front Locker and rear LSD mr x Items Wanted 2 03-13-2008 09:59 PM
4.30 gears into a 93 P/U?? CoedNaked General Vehicle Related Topics (Non Year Related) 4 03-18-2006 01:11 PM
what gears do I need dbright 86-95 Trucks & 4Runners 6 01-08-2006 04:32 PM
open diff. gears are the same as TRD locked gears???? byron4 Offroad Tech 3 05-02-2005 12:35 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
