| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
show me your valve cover
#2 (permalink) |
yes it is ok ... Normally that port is "vented" back into the stock air cleaner .. but since you dont have one !!! ..
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come . 84 2WD "hotrod" Intercooled 7MGTE 83 Trekker SR5 CURRENT BUILD My home page MY PAGE 2WD fourm I frequent NEW Trekker forum |
#3 (permalink) |
but it gets vaccume when it is attatched to the stock air cleaner it seems to me like this is a big hole in the system
#4 (permalink) |
I had a vent like that on mine and got water in the engine and had to do a head gasket so I put a tube from there to my air cleaner in my weber
__________________
81 Toyota 4x4: 22R, weber carb, long tube header w/custom exhaust, L45 4 speed, 4.56 V6 3rds, TG highsteer, RUF w/sky shackle, custom rear springs w/shackle, 2" BL, 32x11.50x15 BFG MTs on 15x7s(street), 37x13.50x15 DC FC2s on 15x8s(trail), ARB air compressor, KC lights, topper... |
#5 (permalink) |
You know it gets vacuum? I'm pretty sure it's just a vent. Gases come out of the valve cover through it, and rather than just releasing them back into the atmosphere, they get circulated back into the engine. I don't think it has anything to do with vacuum. I'm pretty sure most people with a weber carb have a setup exactly like yours.
__________________
Zach '83 Shortbed 4x4 L52HD Rebuilt & Mostly Stock |
#6 (permalink) |
http://media.photobucket.com/image/w...t/DSC03653.jpg
http://media.photobucket.com/image/w...er%202/006.jpg I saw about as many examples of people with it routed back into the intake as I did like the above links...
__________________
Zach '83 Shortbed 4x4 L52HD Rebuilt & Mostly Stock Last edited by 83; 10-28-2009 at 09:02 AM. |
#7 (permalink) |
its just a vent. stock goes to the top of the carb.
Al
__________________
81 Toyota pickup 22r, 5spd, 4x4, longbed on 33's... custom suspension in the works. 79 Cherokee Chief Widetrack "Kronk" TBI350, SM465, NP205, Hydraulic clutch, Hydroboost, Custom aluminum radiator, Flowtech headers, SOA D44HD w/ Hi-steer, D60, 36" TSL/SX's, LED tail conversion... 91 Chevy K1500 - The Hauler TBI350, built 700r4, NP241, awaiting 4" lift... 90 XJ - 5.5" lift, 33's, bushwhacker cutouts, sliders, bumpers, winch... 08 Mazda CX9 - Zoom-Zoom! |
#8 (permalink) |
yeah.....no vacuum - it's just a vent. my 82 has that exact same setup for the past 3 yrs....no probs.
__________________
1982 2WD Pickup (1 owner - ME) 1982 Trekker |
#9 (permalink) |
I just installed a Weber 32/36 on my 83 4x4 and it goes connected to the underside of the airfilter. I bought a line at OReilly last night for like $4 to connect from the valve cover to the air filter. You should be ok the way it is...my brother didnt have anything on it at all and he didnt have any problems. Stock goes connected to the air intake.
#10 (permalink) |
i believe it is under vaccume from the intake of the carb.the pcv valve needs vacume to work and they are both on the same air channel on the valve cover.im just trying to under stand this stupid little thing better.i value all your opinions thanks for the replies
#11 (permalink) |
Well if it's under vacuum from the carb, as long as there's no gaping hole on the carb side, there's no vacuum leak. Right?
I know you're thinking it's a problem, but it's really not. If there's a place on your carb then go ahead and buy some hose and connect the two, otherwise don't worry about it. I did some search on "valve cover breather" or something like that, if you do the same you'll get some answers. Sometimes it vents, and I think sometimes it sucks air in. As long as it is allowed to vent, and when it sucks air in, it's not sucking in dirt, water, etc. (thus the filter), it's fine.
__________________
#12 (permalink) |
if you can pull a vac. from that port on the air filter you need to change your filter.
__________________
'82 toyota pickup 5" lift, weber 36deg carb, 32x11.5 sx super swompers,rear aussie locker,5.29 gears, cb, and 261*c cam |
| Tags |
| 91, cover, image, location, pcv, pickup, show, toyota, valve |
