YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Pre 84 Trucks
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-27-2007, 09:23 PM   #1 (permalink)
Island_Yota's Avatar
Pinion angle + Shackle angle
Whats and ideal pinion angle for the front and rear? Where do I measure off of with my gauge, The flat surface above the pinion? Im gonna run some longer shackles but dont wanna throw it off too much.
And while on the subject, whats a good shackle angle? I wanna tweak it once I get the tube deck and cage finished, right now with no load on the rear end they are around 70 degrees I believe, What I did was cut the shackle hangers off and C clamped them a little farther forward on the frame, put about 400 pounds of weight on the frame and they didn't flatten out enough to hit the frame, seem to work good but I want some input I went a little extreme on the first try and they hit the frame so I moved them back a bit. I would also like to know my options for fixing the front shackle angle, its pretty much vertical right now and the springs that are in it are staying in the truck, the shackles barley even move, they are really stiff.. you need a BFH just to move them when the springs are out, the bolts are stuck too, il have to melt the bushings out with a torch im guessing.
Island_Yota is offline
Sponsored Links
To remove this ad, register today!
Old 07-28-2007, 12:27 AM   #2 (permalink)
deserttoy84's Avatar
Send a message via AIM to deserttoy84
http://www.4crawler.com/4x4/CheapTri...line-101.shtml
__________________
1984 toyota sr5 4x4
22r w/ weber 32/36
Pro comp 4" front springs and 3" rear downey springs
D-tech Shocks
33x12.5 M/T , 15 inch weld rims
Hella 550/ Hella h4 conversions with HID
Home made On-board air system
deserttoy84 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Pinion angle adjustment with 1" drivetrain lift Snorkeldepth 86-95 Trucks & 4Runners 3 02-29-2008 08:04 AM
Adjusting rear pinion angle on Gen II 4Runner FredTJ 86-95 Trucks & 4Runners 3 09-18-2006 10:01 PM
Changing pinion angle....SFA Marc P Offroad Tech 8 08-31-2006 12:28 PM
knuckle angle ? bigamigo 95.5-2004 Tacomas & 96-2002 4Runners 8 12-28-2004 04:47 PM
Departure Angle castrolSi 95.5-2004 Tacomas & 96-2002 4Runners 3 12-03-2002 04:41 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
