Part Numbers
Part Numbers
Installing a new air horn soon and would like to get rid of the dash horn button at the same time. Does anybody know the part number for the horn contact pin?
Thanks
Thanks
i think you should be ok with that amount, are you using it to kick on power to a relay?
if you find that part number, let me know. I was at the u pullit today getting some junk for my Tercel and saw 3 2WD 1st Gens in there and did not even think to look for the horn contacts
yea I think I got the number now. But the kit came with the relay push-button and all that jazz, but the compressor only draws .9 amps so i thought to keep it simple I'd just go ahead and run it strait to the compressor. Can't see how .9 amps on a circuit with a 15 amp fuse could hurt; especially because it'll only be ran for 5-sec tops.
Thats the one for an 88, not sure if its the same, but its stocked at the dealer for $2.99
You don't by chance know how it attaches? I can try to guess, but I'd rather not be setting there with the steering in pieces realizing I don't know how to get it on.
rushw
07-18-2015 01:46 PM
