My 82 is a go-cart now - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Pre 84 Trucks
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-16-2009, 10:23 PM   #1 (permalink)
crhannig's Avatar
I changed out my shocks today and as I taking for a test drive about a 1/4 mile away from my mom's home the engine started to like a go-cart.. it was kind of sputtering and not sounding right and then it didn't seem have full power.
After I got all my stuff packed up and headed back to my house. It started all over, I thought maybe it was the gas as I was almost empty. So I stopped and filled it up. Then it wouldn't start, it took maybe 10 cranks to get to fire. once it started it hard to keep it running, I then headed home, it was slow ride as I couldn't get over 35 miles per hour no matter what gear I was in.
My truck sounds like cars you get to drive at Disneyland on their little freeway. it sounds like a go-cart and is about as fast.
All the gauges read normal all the way home. I have no idea what could be wrong, not a mech guy.
it is a 22r with a weber carb.
__________________
C.R. Hannig
1982 Toyota Pickup
2008 FJ Cruiser
crhannig is offline
Old 10-16-2009, 10:26 PM   #2 (permalink)
turboboost's Avatar
I'd be willing to bet it's ignition related. I had a similar problem and it ended up being my distributor cap being filled with corrosion. After I replaced the plugs, cap, and rotor, it ran like the day it came out of the factory.
__________________
1990 Toyota 4Runner - SR5, 22RE, 5 speed, 35" Mud King XT, a bunch of mods.
1986 Mazda B2000 - 5 speed, carb'd 2.0, the winter beater.
1979 Datsun 280zx - 2 seater, 5 speed, stripped interior, etc.
1998 Nissan Altima - 5 speed, 1981 280zx turbo snowflake rims.
1985 Toyota Pickup - SR5, 22RE, 5 speed, Xtra cab, lifted 2", 35" boggers, etc - Sold
1983 Datsun 280zx - Turbo Intercooled L28ET - Crushed.
1985 Nissan 300zx - 5 speed, race prepped, etc - Crushed.
IFS Club #7
turboboost is online now
Old 10-16-2009, 10:48 PM   #3 (permalink)
crhannig's Avatar
I will check that out in the morning, thanks for the info
__________________
C.R. Hannig
1982 Toyota Pickup
2008 FJ Cruiser
crhannig is offline
Old 10-16-2009, 11:08 PM   #4 (permalink)
turboboost's Avatar
Quote:
I'd just check the plugs first, it's a possibility they could be fouled, I've seen that happen many times before too.
__________________
IFS Club #7
Old 10-17-2009, 11:34 AM   #5 (permalink)
crhannig's Avatar
BTW the plugs, distribuator and wires all looked good.
I took off the air cleaner and it smelled like gas, and was sorta wet with gas. The carb looks clean, but the floats do stick when it being started and afterwards the exhaust smells like fuel.
__________________
C.R. Hannig
1982 Toyota Pickup
2008 FJ Cruiser
crhannig is offline
Old 10-17-2009, 03:36 PM   #6 (permalink)
crhannig's Avatar
I tried some carb cleaner that did not help. I did notice what looks like some fuel leakage under the carb though.
and then looking more at motor I found something that I am not sure if is suppose to have a hose hooked up to or not.
and if it does need a hose, I have no idea where it connects too.
__________________
C.R. Hannig
1982 Toyota Pickup
2008 FJ Cruiser
crhannig is offline
Old 10-17-2009, 03:56 PM   #7 (permalink)
peow130's Avatar
that hose goes into the stock airfilter thingy for the carb.
just plug it up, because that's a vacuum leak lol
__________________
1987 Toyota Pickup DLX. 30" Cooper Discoverer S/T's. 1" AAL lift and Tbar crank. and two KC HiLites. IFS Club #5
1978 Camaro Z28, 454 Big Block V8 with a 4 Speed.
peow130 is offline
Old 10-18-2009, 06:14 PM   #8 (permalink)
My lil yota did that same thing. I pulled the valve cover off and noticed that the top timing gear bolt backed off. The truck still ran but not good at all. I tightened the bolt back down. When I tightened the bolt back down the timing went right back to normal. So I guess I got lucky. So you might want to check that!
komh98 is offline
Old 10-18-2009, 08:50 PM   #9 (permalink)
crhannig's Avatar
Quote:
Thanks,< I give that a look.
__________________
C.R. Hannig
1982 Toyota Pickup
2008 FJ Cruiser
crhannig is offline
Old 10-18-2009, 09:23 PM   #10 (permalink)
82odyota's Avatar
its a far shot but its not impossible with ur low fuel level u sucked some junk up and now u have a restriction in ur filter? just something to check. and its cheap to change and should be done more than most of us do anyway. Spark, Air, Fuel. get those and go more in depth.
__________________
82' 22r ,weber ,5.71 , 39.5 truxus sts, header, RV cam, valves, valve springs, 6" lift springs, 2" shackels 3" body. lot of od krylon ,smittybilt front on the back, Gettin paint, highsteer, and lookn to get rid of tires.
82odyota is offline
Old 10-21-2009, 07:38 PM   #11 (permalink)
red1983's Avatar
x2 on the fuel filter. I had wierd stuff happen w/ a clogged fuel filter, I wonder if all that extra fuel in/around the carb is because in attempting to get it moving/ started you're flooding it out. I would assume that the carb is not nessicarly the place to start, I think it is a product of the problem, not the problem itself, but I also have never had this issue.
__________________
1983 longbed Pickup 4x4
former truck: 1983 toyota pickup shortbed
red1983 is offline
Old 10-26-2009, 08:52 AM   #12 (permalink)
crhannig's Avatar
we found out the problem this weekend.. Need to rebuild the carb, part of the problem is the Accelerator Pump Diaphragm has tears in it.
and while we got it apart we are going to the vent mod to make it climb.
__________________
C.R. Hannig
1982 Toyota Pickup
2008 FJ Cruiser
crhannig is offline
Old 11-02-2009, 12:35 PM   #13 (permalink)
crhannig's Avatar
Well I got the carb rebuilt and slapped on and suprise the truck is still running bad. We did a compression check and #3 & #4 Cylinders were very low. The guy doing the work is going to dig into the engine and see what is going on.
__________________
C.R. Hannig
1982 Toyota Pickup
2008 FJ Cruiser
crhannig is offline
Old 11-02-2009, 10:26 PM   #14 (permalink)
crhannig's Avatar
Well it looks like I need a new head. the head gasket is shot between the #3 and #4 cylinders, along with the head. there is about an 1/2 gouge between the cylinders with a dip/divot in the middle.
It seems when that happened it backfired thru the intake manifold and out the carb, which is what fried the Carb.
Now i am trying to find a new head for 82 22R.
__________________
C.R. Hannig
1982 Toyota Pickup
2008 FJ Cruiser
crhannig is offline
Old 11-02-2009, 11:08 PM   #15 (permalink)
22RUCRAZY's Avatar
engnbldr.com i am very pleased with the cylinder head i got from them , There are cheap ones on ebay but some are junk
22RUCRAZY is offline
Old 11-03-2009, 06:51 AM   #16 (permalink)
crhannig's Avatar
Quote:
The problem with the ones from engnbldr.com is that they are from 1985 on up. Which has different shaped ports, which means... new header and intake manifold.
__________________
C.R. Hannig
1982 Toyota Pickup
2008 FJ Cruiser
crhannig is offline
Old 11-04-2009, 04:41 PM   #17 (permalink)
22RUCRAZY's Avatar
Ouch didnt realize that , you should go for a 20r hybrid
Old 11-06-2009, 07:09 AM   #18 (permalink)
crhannig's Avatar
Got a new head ordered last night, now just waiting on FedEx to deliver.
__________________
C.R. Hannig
1982 Toyota Pickup
2008 FJ Cruiser
crhannig is offline
Old 11-11-2009, 07:58 PM   #19 (permalink)
rowdy235's Avatar
Sounds good, good luck on gettin her going again
__________________
The Daily Driver:
1998 Tacoma | Regular Cab | 4WD | 2.7L | 5-Speed Stick | Mostly Stock
The People-Hauler
1988 Grand Wagoneer | SUV | 4WD | AMC 360 | 3-Speed Auto | All Stock
The Dump Runner
1982 Pickup | Regular Cab | 2WD | 22R | 5-Speed Stick | Custom Exhaust
FER SALE! http://www.yotatech.com/f108/1982-sh.../#post51229916
rowdy235 is offline
Old 11-12-2009, 09:53 AM   #20 (permalink)
crhannig's Avatar
Got the new head and gasket set dropped off to the guy doing the work. Hopefully I will be able to be up and running really soon.
__________________
C.R. Hannig
1982 Toyota Pickup
2008 FJ Cruiser
crhannig is offline
Old 11-12-2009, 11:36 AM   #21 (permalink)
Teuf's Avatar
Send a message via AIM to Teuf
Dang, keep us posted n take some pics.
Teuf is offline
Old 11-12-2009, 12:34 PM   #22 (permalink)
crhannig's Avatar
I need to get some pics of the old head, which I can do when I go drop it off to get my core charge money back for the new head.
__________________
C.R. Hannig
1982 Toyota Pickup
2008 FJ Cruiser
crhannig is offline
Old 11-19-2009, 07:47 AM   #23 (permalink)
crhannig's Avatar
I got the message last night that my truck is back to being road worthy. I am going pick it today afterwork. This weekend I will take it out and test it out.
__________________
C.R. Hannig
1982 Toyota Pickup
2008 FJ Cruiser
crhannig is offline
Old 11-19-2009, 09:10 AM   #24 (permalink)
83
83's Avatar
Awesome
__________________
Zach
'83 Shortbed 4x4
L52HD
Rebuilt & Mostly Stock
83 is offline
Old 11-19-2009, 03:37 PM   #25 (permalink)
crhannig's Avatar
Quote:
Originally Posted by 83 View Post
Awesome
Thats how I feel!!!!!!:bo unce:
__________________
C.R. Hannig
1982 Toyota Pickup
2008 FJ Cruiser
crhannig is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
