First post! Aisan carb on my '81?
Just a quick question, I am trying to determine what the original carb was on my 1981 2WD 22R long bed truck. I just bought the truck from a guy that says he rebuilt the carb.
Right now it is Aisan 2A14 Toy-500
Is that the right one?
Thank you !!!
Thank you !!!
Aisan and Asco are definately stock Toyota parts. The hubs on my 82 are Aisan and the hubs on my dads 80 are Asco. The carb on my 82 22R is an Aisan. Not sure on the number of it though.
I've got a Canadian model truck and if I remember correctly I only have 6 vacuum lines on the motor. I don't see why it wouldn't run well if you took off all of the Cali stuff. One thing that I think is different on our carbs is the idle mixture screw is different. I remember looking in my FSM and the Cali models were different from mine.
there should be a metal tag on the carb with 5 numbers on it...something like 51030 or something (im sure thats not the correct numbers) Its attached with a screw near the top/middle, and supposed to be a shiny thin metal tag. Prolly covered in gunk being this old, but that number is what you will need to compare to.
thanks guys! i got it figured out which one i got and decided to stick with it instead of going to a weber. motor should be going back in next weekend.
