broken timing chaing guides
found out while replacing my head gasket that the timing chaing guides are both broken. Pass side only about the top inch, above the bolt, and drivers side the top bolt hole was broken, so it's loose on the top. my inclination is to do the metal timing set up, but I just got laid off, so money is tight at best. what do you guys think?
Dang it! yeah, I don't know how many times I have to learn that lesson before it'll finally sink in, but it's at least one more time. Thanks guys. So it's metal timing chain guide, oil shaft seal, crank shaft seal... and that's it? I hope so cuz my credit card is lofty and no income... ummm
jon.r
07-11-2015 03:34 PM
