1983 Toyota trail truck FS Georgia
Up for sale is my 1983 Toyota 4x4 trail truck, rock crawler. It runs and wheels offroad great. It leaks and creaks like most old yotas but I crawls like a goat every time. This truck is has a registered tag and is driven on the street, but still needs turn signals and a rear view mirror, you can drive it home if you want. The stock doors come with it also but they no longer fit in the door frames. The truck has been flopped once at chocoloco mtn in Alabama, but has usual rock rash as well.
$6000 OBO
Please PM me if interested
In no particular order...
Corbeu Racing seats with 5 point harnesses
15 gallon RCI fuel cell mounted up high away from rocks and debris
22r motor with carb
5-speed manual tranmission with trail gear knob and Marlin Crawler shift bushing
5.29 gears in the diffs trail gear up front G2 in the rear
front axle is trussed and armored and has the steering stabalizer
Yukon chromoly grizzly locker front
Detroit locker rear
Trail gear Chromoly dirty thirty axle shafts front
Stock shafts rear
WARN hubs
Double transfer case 2.28 front 4.7 rear with trail gear adapter and twin stick, all sticks have a trail-gear knob
Custom drive shafts front and rear
FJ80 high pinion third member front
GM alternator with adapter bracket
FJ80 master cylinder
Steel braided brake lines front and rear
New stock toyota calipers, rotors and pads up front
Trailgear GM rear discs and calipers with adapter
17" black steel wheels
37" 12.50 BFG KM2's
37" 13.50 Toyo open country Mud terrain spare on 17" black steel wheel
Marlin crawler bumper and tube doors
Trail gear lift, springs, shackles, shock hoops, high steer etc...installed by 4wheel parts in Marietta
Fox emulsion shox 14"
Custom inner roll cage and flat bed by mild 2 wild customs in powder springs
Brand new optima red top battery
Smittybilt 8000lb winch and aluminum hawse fairlead
$6000 OBO
22r motor with carb
Detroit locker rear
Stock shafts rear
WARN hubs
37" 12.50 BFG KM2's
the1998sr5
10-19-2016 12:48 PM
FS[SouthCent]: Toyota Trail Gear 5.29 Ring and pinion x2 NEW
YotaLogic
12
11-17-2015 06:27 AM
