| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Welder ?'s
#2 (permalink) |
i have never heard anything good about a harbor freight welder, i have worked with lincoln and miller and both worked excellent mig and tig,
1. What are you going to be welding? 2. How often are you going to use the welder? it could be cheaper to have someone do it, or borrow/rent one 3. Do you absolutely need/want a mig welder? stick welders are cheaper and easier to come by, they weld thicker materials in price comparison to a mig machine. I have seen some really nice welds dont by a stick welder as well it just takes practice.
__________________
i am pretty much open to anything, atleast until i get lockers. |
#3 (permalink) |
Garage sale, Craigslist, and pawn shops are great places to look for a welder. Stick to the name brands - Miller and Lincoln. I think Hobart welders are built by Miller.
I would really recommend getting a 220V 180A or bigger welder for the kind of fabrication we do for our trucks.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#4 (permalink) |
Super Moderator-Sponsoring Member
Staff
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
#5 (permalink) | |
Staff
Quote:
![]() I also moved the thread to the Tool Time sub-forum. Fink
__________________
1985 4Runner 22RE 4WD "Ratchet" 2007 Tacoma Double Cab SB 4x4 V6 TRD Sport AR-TTORA "My work number is 9-1-1." |
#6 (permalink) |
if the welder is just ment for fab work on your rig 110v with high amp output will do you just fine, just remember the thicker the material you may have to prep your steel a little differently rather than just tacking and burning wire. If your mind is set on heavier fab work a 220v machine is what you want. Lincoln, Miller, or Hobart, cant go wrong with either one of those three.
#7 (permalink) |
Hobart 187 mig Welder. Anyone have one or used one? I ordered one from TSC. Was tired of trying to fool with upside down stick welding.
__________________
1994 toyota 4x4. 22re turbo (sds em4, intercooler, steedspeed manifold, garrett t3) 4 inch procomp stage two lift front, t-bar crank(small), trail gear 4 inch rear lift with 6" shackles. ARB bull bar and warn winch, Quick lock rear, tru trac front 35x12.50 Pro-Comp Mud Terrains, 5.29 gears, snorkel, rock sliders Planned mods. , T-case gears, ditch ifs Beware the groove Man, its a shame when folks be throwin away a perfectly good white boy like that. |
#8 (permalink) | ||
lol try to use a mig without gas.
__________________
Quote:
Quote:
1993 yota pickup. 3 slow, 4.56 gears 5 speed. plumbing isr. autopal h4 conversion, 12 inch infinity sub. 3 inch body lift with 33'' tsl's |
#9 (permalink) |
I don't have a problem with flux core.
I ended up buying a lincoln 140c and i really love that little welder.
__________________
Mike 1990 4runner: 3.4 swapped, 5-speed, sas'd, Rear leaf swap, Locked, 5.29's, 39.5" iroks on Beadlocks, Armor'd Longfields, Duals coming soon: My build thread http://www.yotatech.com/f152/904_run...thread-158746/ http://www.treadlightly.org/ http://www.pirate4x4.com/tech/billav...ery/index.html |
#10 (permalink) |
look on craigslist. Because of the economy, tons of people are selling their non-essentials. I guess welders are not essential to most people, since I've seen a bunch of them on craigslist lately.
__________________
1986 pickup 4x4 SR5, 5-spd, 33x10.5 BFG KM1 muds, 2" body lift, front and rear lockrights, 4.88s, 4.7 t-case with Dave'z twin stick, BudBuilt crossmember with 1" drivetrain lift, Downey grille guard and skid plate, TG sliders Still needed: rear bumper (Marlin, TG, or Dave'z) |
#11 (permalink) |
Not knowing your age and economic status I don`t know if you have an account with any of the tool truck people. Long time ago I bought my first welder from Matco tools it was built by Century and still going strong. 25 plus years later.
I would say get the biggest output wise you can afford. You can cry about how hard it is to stick weld but they are so flexible you can go from 3/32 electrode for steel to a cast iron electrode to a stainless steel electrode. while you are still changing out that first spool of wire.
#12 (permalink) |
The hobart is a good welder (140 or 187) but I went with the lincoln 180 because the spool gun for aluminum was a lot cheaper. Miller makes a good welder that a fab buddy of mine uses and its just a plain 180 self set. It just comes down to what you will use it for. I have been doing more and more tubing lately and all I can say is if you can get the 180 mig then do it but if not just make do with the 140 because I can rarely find tubing that I need more juice then a 140 would do. Get gas for whatever you buy... Better looking welds will leave a positive note on the project and make you feel more professional.
__________________
1994 yoda jd fab lt front,62" deaver back,full glass, and kings. 1997 xj the DD/prerunner 1974 bronco 5.8 EFI 4r70w np205 "IN PROGRESS" With the navigation arrow pointed straight at Ihop Aunt Jamaima really likes me cause my syrup is so hot! |
#13 (permalink) |
call me dumb, but can that seriously be done? Im looking into buying a welder too, but mig, tig, flux, im so lost with it all
__________________
1998 Toyota 4Runner: 33" BFG A/T T/A: KO 2.5" Lift CB Radio Brush Guard Yakima roof rack manikin head (Viola), and more to come! Clicky For Picky Buildup GATTORA KJ4HVQ Skywarn Ga 208 ΦΣK DAMN PROUD!
#14 (permalink) |
Yes you can run a self shielded wire. I have heard that it has gotten a lot better since it first came out. i just am not a big fan of it.
#15 (permalink) |
Like I said go mig, get some gas and learn to weld and never look back. Stick is ok for thick stuff, but weld quality just wont look as good in most situations. If you look on ebay you can grab a lincoln 180 pretty cheap if you can handle the 220v230v?) in your shop. If not go for a lincoln 140 or even a comparble hobart unit. For a beginner mig is easy and simple to learn.
__________________
#16 (permalink) |
Here is a link to a buddies build. Most all the welding was done with a miller 180... Nothing special but it just works good. It all comes down to skill and the mig has the versatility to make anyone a jack of "most" trades when it comes to welding.
http://www.race-dezert.com/forum/showthread.php?t=54157
__________________
#17 (permalink) | ||
Quote:
It produces a much more messy, I would strongly advise getting a gas setup welder. Quote:
after that ill spend the money on a gas setup..
__________________
Screw you guys I'm goin to TTORA Mods, please be mature and leave my sig alone, thanks. No, I will not be your friend. |
#18 (permalink) |
me too im using the flux cored sire cause my lincoln mig pak has it in it but once its up ill get the stuff for gas.. it works good worknig on body work.. i have a sand blaster and a grinder to clean welds
__________________
1991 HILUX SURF SSR-X turbo diesel right hand drive toyota imported in 2005 from japan, 130,000 km 31 bfg a/t auto current build 1987 LWB suzuki samurai. turning 2 into one.. yota axles welded front to back, yota springs , ifs steering box,, this bad boy will not only eat jeeps but toyotas aswell \m/ |
#19 (permalink) | |
Wow, for a kid still welding his first project, you became an "expert" awful fast ...
CORRECTIONS This is absolutely not true. Aluminum can be welded with either TIG or MIG. TIG provides much more accurate control over the heat, and when done properly, a better weld. It is also MUCH more difficult to learn, MUCH slower, and the machines are MUCH more expensive (like, try and find one for <$2k). You can weld ANYTHING with TIG. Quote:
Note: TIG is more properly named GTAW (Gas Tungsten Arc Welding) Agreed, but flux DOES have its advantages - better penetration, better tolerance for dirty surfaces, etc
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action Last edited by tc; 04-21-2009 at 08:21 PM. |
#20 (permalink) |
I wasnt trying to sounds like an expert, I was simply stating as much as i knew..
And my kart is not my first project. Also I just finished my second project old man.
__________________
#21 (permalink) |
Banned 'cause I was 4runnerchevy also banned
Another weld Topic !
OK, Flux core (FCAW), set up right, will penetrate better then mild steel (with gas) MIG (GMAW). Scuba: You can do anything with a TIG as long as its AC/DC (aluminum, steel, titanium, 4130, you name it).Choice, get a mig its easier. Set yourself up for Flux and shielded welding. If you can afford it (and have the supply)buy a 220 machine with a minimum of 50% duty cycle. |
#22 (permalink) |
x2 - it's nice to just work on your project and not be setting off thermal shutdown in your machine or blowing breakers in your house!
__________________
#23 (permalink) |
stay clear of the CHItown electric welders from harbor freight AkA china mart.
I used one and the welds are still holding a year later but it was a major pain compared to the Lincoln 140 I have now it is at least 300 times better and 400$ more,I could only imagine how nice it would be to get my hands on a high end Miller. another thing to think of when buying a welder a empty 40lbs or 50lbs tank to buy is going to cost you around 160$ new. I had a co2 tank but i had to buy a adapter for my gas regulator to fit my 100% co2 tank and it ran me 17$ buy the large 12 lbs roll of wire you will save about 20 bucks compared to the 2 lbs rolls. OFN is a good place to find info on welders and a good source to learn about metal fabrication.
__________________
my rigs 89 4runner 1989 4runner v6 5 speed everything factory +4susplift running bfg 31s and a aux gas tank and more aux lights than needed 86 pickup 1986 stock pickup 22r 31.10 BFG ATs flatbed a sad day for the 4runner "One moment of patience may ward off great disaster. One moment of impatience may ruin a whole life." |
#24 (permalink) |
I would guess if you never learned to weld in the SMAW process that ones welds could look pretty bad out of position.
There is no reason for that. If at all possible spend the money go to school learn the basics. I see so many GMAW welds with cold lap sometimes on both legs. If you really want to get picky all metals can also be welded in the SMAW process if one really had to and had the correct electrodes on hand. You can never have enough welders just like you never seem to have enough clamps and grinders. |
#25 (permalink) | ||
Quote:
Quote:
Although I have never gone to school for welding (self taught) I can weld quite well with my lincoln stick. I just have not mastered upside down welding, which is the hardest to master. Ive done some reading on the Miller welding forum and all the experienced guys say that upsidown welding is the hardest regardless of welder and that stick upsidown welding is especially difficult. I had been thinking about getting a MIG for a while anyways and I found a smokin deal on one at Tractor supply. $599 $649 delivered to my door. Normally the Hobart 187 is $849 (at least thats what the website says) I am still going to keep my lincoln stick as versitility is great and if I ever need more than 187 amps of power. Plus you can never have too many welders. As far as CyMoNs comment about Chinese welders. A friend of mines cousin bought a harbor freight plasma cutter and it works great. Also I have a Chinese plasma cutter that I got from eshipyards off of ebay. Best 450 bucks ive spent. Its a 40 amp and it has cut everything I have attemped to cut without even a hicup. There are a lot of people who have had good results with them. And 450 bucks compared to 2 grand from miller etc is worth the gamble.
__________________
1994 toyota 4x4. 22re turbo (sds em4, intercooler, steedspeed manifold, garrett t3) 4 inch procomp stage two lift front, t-bar crank(small), trail gear 4 inch rear lift with 6" shackles. ARB bull bar and warn winch, Quick lock rear, tru trac front 35x12.50 Pro-Comp Mud Terrains, 5.29 gears, snorkel, rock sliders Planned mods. , T-case gears, ditch ifs Beware the groove Man, its a shame when folks be throwin away a perfectly good white boy like that. Last edited by saitotiktmdog; 04-22-2009 at 05:30 AM. |
| Tags |
| 140, 1994, electrode, hobart, lincoln, makes, matco, pirate4x4, stick, supply, tools, tractor, unit, welder |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Welder Help !!! | phildelfino | Off Topic Talk | 7 | 08-13-2008 03:31 PM |
| What Welder Should I Get? | JasonWin | Tool Time | 4 | 04-18-2008 11:46 AM |
| Looking at this welder: | ClemsonToy | Tool Time | 23 | 10-30-2005 12:30 PM |
| I need a welder! | getitdone | Tool Time | 20 | 07-16-2005 08:39 PM |
| What welder to get? | corvettelvr73 | The Fab Shop | 8 | 10-03-2004 07:02 AM |
