PDA
View Full Version : Items Wanted
Pages : 1 2 3 4 5 6 [7] 8 9
  1. WTB: Used or damaged 3.4 harmonic balancer
  2. WTB: Toyota 15x7 Stock Wheels (Pic Inside)
  3. Gray SR5 Drivers Seat-'85 4runner
  4. 4 and 5 speed shifter knobs in good condition
  5. 3rd gen stock cd/tape/radio and clock
  6. >>> TAILGATE hinges .. first GEN
  7. Four bfg km2 35 x 12.50 x 15
  8. 22re 2wd Downey header
  9. w56a/b shifter and top plate
  10. Carpet kit to fit an 86 reg cab
  11. Wheel spacers or fender flares
  12. Wtb: 18" Enkei Wheel (pics included)
  13. WTB 89 v6 mechanical speedo cable
  14. Request for 3rd Gen 4Runner front door panels - locally in Portland OR area
  15. i need a 1st gen runner driver arm rest-gray
  16. Wanted - rubber shift boot w56 top shift
  17. 84-89 4runner wanted
  18. wanted: 37"x12.5x15 junk tire (hemet, ca. 92544)
  19. Need an 01/02 4Runner grill- Trade for my 00?
  20. Wanted: Solid Front Axle
  21. 89 pickup rear DS front flange help
  22. WTB inclinometer for 2nd grn 4runner
  23. 80's parts
  24. Toyota e-locker 4:30/ 4:56
  25. 89-95 Jump Seat
  26. want to buy 1979-83 4x4 long bed truck bed. 500$
  27. Power steering stuff
  28. Looking for ALL BLACK stock front bumper 92 4x4
  29. Trailer in PDX
  30. 3rd Gen 4Runner Front Coilover Assembly
  31. Radiator needed for 22RTE
  32. Gold anodized nuts and bolts
  33. Hilux Surf FMU big $$$
  34. Offroad lights
  35. 1.25 Spacers for rims 6 lug
  36. License Plate Lamp, 1996 Tacoma
  37. 89 first gen runner door panel
  38. WTB 84-88 cab only (x-tra cab)
  39. Dash Mounted Cruise Control Switch
  40. Wire harness repair parts
  41. 1stgen tacoma double cab cab Kansas
  42. 2nd gen truck drivers side marker light
  43. 1st Gen 4runner Rear SR5 Interior Panel Pockets (Pockets only)
  44. WTB. push pull steering box
  45. 89 first gen. 4runner door wiring harness
  46. 96-02 4runner Running Boards
  47. 3rd gen 4Runner running boards
  48. 1989-1995 4WD pickup
  49. Tundra Access Cab Bed Cap
  50. ECM wiring
  51. WTB seatbelts and a rim
  52. 3rd gen t4r headlight pieces
  53. WTB: 2006 Tundra Center Cap PN#42603-AF060
  54. WTB: Used Bridgestone Dueler Revo
  55. WTB 4th Gen Trailer Hitch
  56. Sending Unit 88 pick up 3vz-e 4x4
  57. 86 Headlight/turn signal/wiper combo switch
  58. 22RE Igniter Assembly 89620-35160
  59. 4runner Blue Bucket Seat
  60. 22 ret badges
  61. 84-88 Tilt column plastic
  62. 1986 pickup drivers side door panel
  63. Want to Buy: 1st Gen 4Runner SR5 Glove Box Light Switch
  64. Turn Signal/Headlight Combo Switch 1st Gen 4runner
  65. WTB 3.4 airbox and intake 96-98
  66. 96-02 4runner passenger side mirror/housing
  67. 1994-1996 t-100 3.4 4x4 auto extension housing
  68. v6 booster and master
  69. 1990 panhard drop bracket
  70. 1992 power steering bracket and pitman arm
  71. 1986 List of stuff still needed
  72. 1st gen 4 runner
  73. OEM Toyota Tacoma Manual Hub CV Shafts
  74. 84-89 lighted ashtray bracket and cigarette lighter assembly
  75. 302 V8 to W56 adapter
  76. Stock Toyota rims with 31" tires PNW
  77. 87 4runner battery clamp and tray
  78. Round Toyota U-bolts from flip kit ( 2 U-bolts only)
  79. WTB:Green A/C button,plugs/wires
  80. 1st gen 4runner body/rolling project NJ to VA area
  81. Looking to buy some exterior/interior parts for '93 ext cab!
  82. 89-95 Ext Cab Sliding Rear Window w/Factory Bronze Privacy Glass
  83. Hit a deer and needing a couple of body parts...
  84. Fuel pump bracket 94 x-cab v6
  85. 3.4 fuel injectors
  86. T100 shackles ext cab
  87. WTB - Steering stop bolts (plastic covers not required!)
  88. lookin for an 79-85 sfa pickup or 4runner
  89. Extended cab "needed" for my 95 pickup
  90. WTB Bolts/clips for stock Toyota bedliner '92
  91. WTB- fog lights for a 02
  92. 2012 Taco Fog Lamps
  93. Adjustable cam gear
  94. 1987 window crank, complete signal/wiper switch
  95. 1984-89 SR5 4runner Gauge Needle Set
  96. 22re knock sensor pigtail
  97. first gen 79-83 blue sr5 steering wheel and tilt column cover
  98. 1989 1st gen 4Runner SR5 door panels - L & R
  99. Fuel pump bracket '92 SB 4x4 truck
  100. 3.4 trd supercharger
  101. 99-02 Fog lights
  102. '80 Pickup Marker Lights
  103. Tacoma ECM
  104. 1st gen front bumper or brackets
  105. WTB..TRD 3.4 S/C Belt tensioner mounting bracket
  106. 87 4Runner TPS Plug
  107. 4wd VSV 3rd gen 4runner
  108. Toyota 3.4
  109. wtb wiring harness for a 1990 toyota p/u 4x4 manual
  110. SR5 5 speed shifter surround, grey
  111. 5vzfe drivers side valve cover
  112. 2nd gen power antennae and interior parts
  113. 3rd gen body parts
  114. stock front bumper and grill for 3rd gen 4runner
  115. '93 pickup rear bumpstops
  116. Cruise Control Actuator (T100?)
  117. 1st gen 4runner gray dash pieces
  118. WTB SB Chevy Adapter
  119. 1st gen 4runner rear driveshaft..
  120. WTB: factory cd player, 5spd knob, power antenna assy
  121. 89 SR5 V6 gauge cluster
  122. coil springs
  123. 90-95 4Runner Grey Dome Light
  124. AA for 700r4/4l60 to toyota t-case or AA lsx to w56 bell, flywheel, flex etc..
  125. Tundra TRD Coils and Tacoma Manual Hub CVs
  126. i need a few 85 interior runner parts
  127. WTB 1994 4Runner 22re 5-speed ECU
  128. 1st Gen Pickup gauge lighting
  129. Aftermarket bumper wanted for 2001 Taco
  130. second gen extd cab
  131. Need Toyota T100 Camper Shell
  132. Power mirrors for 1st gen 4runner/PU
  133. 3rd Gen 3rz for swap
  134. ext. window weatherstripping seal
  135. Wanted:Toyota 4 inch speakers
  136. need some 35's
  137. 3rd gen. pickup doors
  138. Aisin Manual Hubs IFS
  139. WTB- 04 Taco xtra cab Door - Black sand pearl
  140. Timing belt & water pump replacement. Looking for a COMPLETE kit.
  141. 5vzfe fan, fan clutch, and shroud
  142. Factory leaf pack rear not sagging.
  143. Roll Bar / Light Bar
  144. 1st Gen 4Runner Driver's Window Channel Rubber
  145. Frame Grommets and brackets
  146. 3vze intake hose arm
  147. WA: 85-86 22re engine harness
  148. where to find a new 22r-te exhaust manifold!!
  149. 1994 4runner Ingnition switch assembly
  150. WTB 82' Supra AFM + 91' Pickup Misc
  151. Want to buy spider gears
  152. 2010 or 2011 4runner 20" factory wheels
  153. tacoma 95 4 cylinder
  154. 2nd gen SR5 seats
  155. WTB- Fuel Gauge for a 1982 Toyota 4x4 WORKING!!
  156. Wtb plastic trim around shifter
  157. 1984-1988 Red Valance
  158. 1st or 2nd gen trd supercharger
  159. 89-95 throttle body
  160. 01 Tacoma front end parts for conversion: flares, hood, bumper, grill, etc.
  161. running Lexus LS400
  162. Complete Bed for a 92 toyota pickup anywhere in Texas
  163. ECU - 1988 3vze Manual
  164. Looking for driver's side rear bumper end cap
  165. Wanted DEAD Yota Truck
  166. WTB: first gen or third gen pickup
  167. Looking for a 79' - 88' Pickup
  168. SR5 Gauge Cluster
  169. speedo cable
  170. 96-98 sport / base front bumper
  171. Wildernest Camper
  172. 3rd gen tan leather rear headrests + dash trim
  173. Toyota Pickup frame
  174. Looking for coils
  175. WTB: 20 pin stock amp
  176. Fan shroud for 1996 4runner 5vzfe
  177. Turbo exhaust manifold? header?
  178. 4runner headlight switch assembly
  179. WTB: 3rd gen 4Runner Tail Light Guards
  180. Want to buy Non-ADD driver's side gear shaft
  181. wanted: carb for 87 22r
  182. 1988 4runner Door Panel Trim
  183. 3RZ M/T Flywheel for my 1999 4Runner
  184. 4.56 auto disconnecting front diff for 99 4Runner
  185. 4.88 IFS front diff complete
  186. 2nd Gen 2WD transmission crossmember
  187. TC Gen. 1 Caddy Kit Weld-On Shock Hoops
  188. WTB Fender Flares
  189. Wtb: 96 Tacoma Seat belt
  190. Power Steering Reservoir
  191. WTB: dash carpet, mudflaps
  192. 2" Class III receiver for '93 Pickup 4x4
  193. Supra AFM
  194. Parts for 3rd Gen
  195. Wanted: Stock TRD Coilovers, Rear Bilsteins AND 31x10.5 wheels/tires
  196. wtb: manual windows/door cards from 4runner
  197. Igniter 81 22r
  198. '82 power steering set up
  199. '87 4runner ECU/ECM needed
  200. Want to Buy: Power Steering Box for 1984 extracab 4x4 pickup
  201. Frnt/rear 2nd gen 4runner bumpers/sliders
  202. 96+ Tacoma Ext cab 4x4 6 cyl
  203. Sport hood
  204. Knock Sensor Pigtail
  205. Need help finding w56 Transmission parts
  206. Fuel pump bracket for 85 pickup 22re
  207. Need a 3.0 intake
  208. WTB: 22re mass airflow sensor...
  209. solid axle Pickup frame...
  210. Or Trade: 4 FJ80/LX450 OEM Wheels
  211. wtb 4.88 gears
  212. 2004 Tacoma bed (or complete bed similar to 2004)
  213. ** Wanted ** 08 Tacoma Bumper and Window
  214. 2WD Stock U-Bolts for 88 PU
  215. In tank fuel sending unit
  216. 1st gen 4runner SR5 seats
  217. New/Low Mileage Lifted Front Strut Assemblies Complete, RevTek Spacer type ok, others
  218. Mud flaps, 86-95 Alloys, Buckles
  219. Want to buy "Search Lamp Assy" for 1986 exta cab
  220. 96 4runner rear hatch
  221. 99-00 4runner A/C button and climate control face plate
  222. 3.4L Radiator, fan blade, fan shroud, and all mounting hardware
  223. Arm rest, trim, rear bumper, misc 1989 4Runner
  224. 1994 22re egr temp sensor on the cheap
  225. 4.88 front and rear diff
  226. '82 supra afm
  227. WTB: 86 turn signal/lights wiper combo switch
  228. SR5 Instrument Cluster for 87 4runner w/22re
  229. Need all the Hardware Bolts for Front Grill
  230. 1979 Toyota Pickup Wiper Transmission/Linkage
  231. Misc 2nd Gen Truck Parts
  232. 3vze engine mount for 11/87 to 08/88 block.
  233. 97 4runner 2.7l parts wanted
  234. URD 2.2 pulley
  235. 00-02 4runner Sport Black Grill
  236. Looking for a factory radio for a 91
  237. Windshield wiper switch on colum with arm attached, Topper to fit 87 rn63 4x4 pickup
  238. 3rd Gen. parts wanted
  239. AC condenser, Hubs, Parking Brake Cable for 1994 4Runner
  240. NEED.. A working ignitor/coilpack for a 82 Toyota 4x4
  241. O2 Sensor Plug
  242. land cruiser 80 or lift springs
  243. 6-8in lift springs
  244. NEED a working light switch for an 82 or 83 SR5 no tilt wheel.
  245. 94 pickup lamps
  246. WTB: 96 4runner Door Mirrors
  247. I want a Smitty built style tube bumper
  248. 2000 Sport Parts Needed (flares, steering wheel, bumper, valance and MORE)
  249. 1999 4Runner ECU 89661-3D640 3RZ-FE 4X4 MT
  250. WTB: Mi. Full body shell or both drivers side doors
