Items Wanted Vehicle and non vehicle related
22re knock sensor pigtail
Old Dec 30, 2011 | 06:29 PM
1993toy's Avatar
Just seeing if anyone has a hacked up wiring harness for a 22re. I broke my knock sensor electrical connection and am looking to cut off the wire and connector so that I can splice it on my harness. If you have anything it would be greatly appreciated. It is for a 1993 22re.
Old Jan 1, 2012 | 06:40 AM
coryc85's Avatar
I believe I've got that puppy...$10 plus shipping. I can either do flat rate shipping which is $5.20 for the smallest box or I can put it in the smallest box I can find and just have it weighed, I'm guessing it will be cheaper that way.
Old Jan 1, 2012 | 07:49 PM
1993toy's Avatar
Connector looks different than mine. What year is it off of? I hate to ask but could you take a picture of the connector head on ( the part that plugs on to the knock sensor). I just want to see if the grooves are in the same place so that it will slide on the sensor I have and lock on. Thanks for the response.
Old Jan 2, 2012 | 05:11 AM
coryc85's Avatar
No problem. I'm not exactly sure of the year, I bought the engine from a guy, I'm pretty sure he said it was a 90's model pickup engine. Here are 2 more pics, there is a number on the plug that you can see in one pic, 11363.
Old Jan 2, 2012 | 09:23 AM
1993toy's Avatar
Thanks for the pics. I looked on my truck and that is the pigtail for the oil pressure sensor. I need the knock sensor pigtail. That is the sensor that is on the same side of the engine block. It is in between the oil filter and the fuel filter. I do not have a camera, I can get one later to take a picture of the location if you need me to. Again thanks alot, I appreciate the detailed pictures and the help. If you have that pigtail could you take a pic.
Old Jan 2, 2012 | 12:13 PM
coryc85's Avatar
So sorry man, my fault. I don't have the knock sensor pigtail, just the oil sender.
Old Jan 8, 2012 | 07:57 PM
dragr1's Avatar
I have a harness from an '86 that I'd be willing to cut up if it might be the same plug?
Old Jan 18, 2012 | 09:36 AM
1993toy's Avatar
I ended up finding the part numbers to buy a pig tail at the dealer. I figured that I would post to maybe help someone in the future. The truck is a 1993 22re. The knock sensor connector is part number 90980-11166. The terminal wire that goes into the connector and then can be connected to the wiring harness is 82998-12440. After going through alot of postings I seemed to find alot of similar problems but no solution so I figured this might help someone else.
montanatruck
Feb 26, 2017 07:07 AM
nonstop
Jul 24, 2015 06:29 PM
smiley52
Jul 11, 2015 05:16 AM
