What happens when I put negative line to positive terminal(+) battery terminal?
SubscribeHi,
I have a 99 4runner manual 4WD 3.4. I accidentally put a negative lead to positive terminal on the battery. I know it's ridiculous. It happened because the battery terminals were on the opposite side because the battery was not for the truck. Regardless, I saw and smelled the ALT(120a) fuse blown so I replaced it. But now the radio is not working..
I was wondering if there is other fuse that was supposed to be blown that prevents the radio not to turn on.
thank you!
thank you!
millball
close
- Join DateAug 2013
- LocationSouthern Arizona
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:683 Times in 503 Posts
Total disruption of the fabric of time. Bad cess.
Your owners manual should give a fusebox image, and what the fuses serve. Google might find it as well.
You may well find any number of different problems that you have caused, over time.
Is the truck running again, and the alternator charging??
Thank you of the reply. Yep, the truck is running great actually. Alternator is charging and everything is well except for the radio. I also have an issue with rear parking tail light and dash light which I don't think is related(I know I have a non working rheostat which will take care of the dash light problem and hopefully rear parking light..?)Originally Posted by millball
Total disruption of the fabric of time. Bad cess.Your owners manual should give a fusebox image, and what the fuses serve. Google might find it as well.
I was looking at google and searching for dumb people like me but no one has done it.. What kind of fuse would I have blown?
millball
close
- Join DateAug 2013
Quote:
https://www.google.com/search?q=1996...QP9jqcPkLbM%3A
Yep.Originally Posted by millball
Have ya looked in there:https://www.google.com/search?q=1996...QP9jqcPkLbM%3A
I know that there are two fuse boxes: one in the driver side kick panel and one in the engine bay. I check both and no fuse seems to be affected by it. I would think Alternator fuse is the only one that was supposed to blow..?
My friggin dumbness man. I'm telling you
millball
close
- Join DateAug 2013
If there is no blown fuse, I guess the next thing would be to determine if there is truly 12v being supplied to the radio.
If there is 12v at the radio, there is either an internal radio fuse that is blown, or maybe the radio is baked.
Just what was the ground lead coming from because that is what the current flowed through to ground
I am guessing the radio worked before this little mishap ??
It may have been much worse the fire department might have been there to keep other buildings from burning to the ground.
Burning two vehicles the garage and the house tends to make me real careful in my older days also impossible to get any type of Fire Insurance that is not more expensive then my yearly Gross income.
Fossilized
dropzone
Fossilized
close
- Join DateOct 2005
- LocationPNW
iTrader Positive Feedback100
iTrader Feedback Score(6)
Liked:456 Times in 301 Posts
A lot of radios (stereos) especially aftermarket stereos have a fuse mounted on the back of the unit
