1985 4Runner $5500 Central ALabama **$OLD***
Subscribe
Aug 22, 2018 | 03:31 AM
This was right after i bobbed it, only pic I have with top on.
Toyota 4Runner 1st Gen.
1985 only year 4Runners had sold axle and multipoint fuel injection system.
I purchased stock in 2012
22re rebuilt last summer
-bored cylinders, Milled head, cam, rock ripper header, new valves, timing set, water pump, oil pump, fan clutch, oil sending unit, TPS, EGR delete, and 140amp HO alternator.
-W56 Manual transmission with new clutches, pilot, throw out bearing, and seals
-transfer case rebuilt 4:70 gears, new bearings, HD shafts, twin stick
-both front and rear differentials have been completely rebuilt with 5:29 gears locker in front, full spool in rear.
-Rear has 63" Chevy springs with LRO shackles, u-bolt flip kit and spring hangers.
-Front has RUF with Hysteer, cross over steering gear box, drop spring hanger, u-bolt flip kit, axles moved forward 4".
-Body has been bobbed 13", rear fender wheels tubed 3", front trimmed 3".
-Inside, after market seats digital tach, oil pressure, voltage meter, hydraulic E-brake, great heat, no AC, 2 wake speakers, 4 marine speakers, roll bar, sub wires ran.
-8500 lbs super winch on trail gear mount, smd green rock lights a few have been smashed but overall they still work. Two led light bars front, led backup lights. Snorkel
Included extras
Have hard top that is cut down 13"to match, half doors, DHW swinging spare tire carrier, 2 good spare drive shafts, tail gate.
Could go rock crawling today nothing wrong, I drive 100 miles to work every couple of months so it does not just sit. Only reason It's for sale is dont ride enough anymore. Clean clear title in hand. However it's not perfect it's got a few dents and rock rash, tires have 75% tread but I mounted myself and never balanced them does fine under 65 mph. Driver seat has a small cut. Back seats are original and you can tell by the discoloration. Back glass in top and side glass is lexan now after I bobbed old ones did not fit but I still have it. Next day off work i'm going to clean it up and cut off the cage around driver rear corner.
$5500 OBO will hear all offers or trades
Reply 0
Aug 23, 2018 | 01:39 AM
sold sold sold
Reply 0
