No high beams - no bright lights
Subscribe
Apr 29, 2009 | 07:29 PM
has anyone come across this? my low beams are fine but hit the brights and nada no light, the dash indicator comes on but the lights just go off. put in new bulbs. is it the switch or the relay?
Reply 0
Apr 29, 2009 | 07:37 PM
I had the same problem last year. It turned out to be the combination switch that controls the lights, wipers and turn signals. I got mine on Ebay and it was easy to install.
Reply 0
Apr 29, 2009 | 08:32 PM
Yep, common problem. Often just dirty or pitted contacts in the dimmer switch:
- http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
Reply 0
Apr 29, 2009 | 08:35 PM
when you pull back and use the flasher do they turn on?
EDIT: 4crawler beat me to it. I was gonna put that link up. I just fixed mine today using that page. A little different on my first gen but you wont have that problem.
Reply 0
May 1, 2009 | 03:02 PM
no brights either way but ill try and give it a good cleanin see how that goes
Reply 0
May 19, 2009 | 07:38 PM
I remember there being fuses for your high beams in the fuse box in your engine bay. Might want to check them.
Reply 0
