hi right now i have a 93 pickup 4x4 that only has 136000 but the frame is junk and i have a buddy who has an 85 4runner frame that is good i was wondering if anybody knew if the body mounts would line up or would i have to do some fabrication
thanks crazycruzjr
thanks crazycruzjr
i just did my 88 truck on a runner frame fit awsome but u ar guna have to move cab mounts on the frame its easy just need a welder
ok cool thanks yea that wont be a problem im renforcing the frame before i do the switch to make sure it doesnt break or rust very easily
later crazycruzjr
later crazycruzjr
just check ur wheel base i think there the same as the short box my buddy runs a 4runner drive shaft in his 92 short box so it should b the same good luck with the swap
84 yote
84 yote
The extra cab pickups run a long wheelbase, so make sure its not extra cab, or upi'll have to bob the bed alot.
The shortbed pickup and 4runner have the same wheelbase.
Just gotta move body mounts around. Not that hard.
it is a short bed regular cab the body is the one in my avatar thanks for the info everybody
later crazycruzjr
later crazycruzjr
