Heim Joints for Tie Rod Ends
Subscribe
Aug 27, 2010 | 09:55 AM
So I think I figured out a pretty good setup.
First I ordered 2 of these
http://www.ruffstuffspecialties.com/...sort=2a&page=2
Using Promo Code JEEPZ to get 10% off for a total of $96 with shipping.
Then I ordered 2 feet of this
http://www.ballisticfabrication.com/...OM_p_1218.html
Using promo code bal10 to get 10% off for a total of $27.95 with shipping
Then I ordered 2 of these
http://www.speedwaymotors.com/Adjust...Heim,3333.html
(Got the 1/2' ones for the pinto) for a total of $27.28 with shipping
Total Damage= 151.23.... Not bad compared to $500.
Ill let yall know how it goes and post Pics ASAP
Reply 0
Aug 27, 2010 | 10:15 AM
I agree that should make a sweet set up. Are you heim's 3/4"? Those adapter from speedway motors are sweet. I am planning to make my own, never knew you could buy them. Hopefully I will have mine done this weekend, well see.
Reply 0
Aug 27, 2010 | 11:18 AM
Yea the Heim is 3/4" but with the misalignment spacer it brings it down to 5/8". If you do get it Done post some pics!
Reply 0
Aug 27, 2010 | 11:25 AM
very interested to see how this turns out scribed.
Reply 0
Aug 27, 2010 | 11:50 AM
  #25
Will def. get some pics up once I get it done. I thingk that we have the exact same Heim's. Now I am wishing that I would have gotten those adapters from speedway motors, but I am going to keep going with my original plan for now. Here are some pics (not mine) that I stole off of another forum.
Reply 0
Aug 28, 2010 | 05:58 AM
  #26
Plan to machine some tappered adapters today since I didn't order the ones from Speedway Motors. It's going to be alittle extra work than buying them would of been but it's too late know. I have ton a ton of measuring & searching on-line & best I can tell my spindles have a 4 deg. taper. Can anyone confirm that?
Reply 0
Aug 30, 2010 | 05:57 AM
  #27
I got some work done on my Heim joint / Tie rod end conversion. I didn't have any steel tubing laying around, so I ended up using some solid 4140 & just drilling & tapping the 3/4-16 right & left hand threads. (major overkill) Also made some stainless steel tapered bushings to adapt the heims to the knuckle & drag link. The bushings are 5/8" OD to fit nicely inside the heim's misalignment spacers & 1/2" ID to clear my bolt. I still don't have them on the truck, but here are some pics of the progress.
Reply 0
Aug 30, 2010 | 06:02 AM
  #28
I wouldn't want to drop one of those on my bare feet.
Reply 0
Aug 30, 2010 | 06:05 AM
  #29
Quote: I wouldn't want to drop one of those on my bare feet.
LOL. Belive me I wouldn't either. They are pretty heavy.
Reply 0
Aug 30, 2010 | 07:34 PM
  #30
you need a toe ring...
Reply 0
Sep 1, 2010 | 05:28 AM
  #31
I got the drivers side installed last night to check for clerance problems. I was expecting 1 or 2.
You can see in these pics how close they come to the castle nut on the pitman arm to draglink.
Never touches though. I will probably turn another 1/8" off of the shaft anyways.
Also the head of my bolt does contact the frame here. It just barelly touches so I am going to try & cut an 1/8" or so off of the outboard misalignment spacer & that should cure the problem.
Other wise everything fits great! My taper adapters work perfectlly
I did make sure that I didn't have any toes showing in these pics.
Reply 0
Sep 1, 2010 | 01:21 PM
  #32
also you could shave the edge of the drag link all the way around and make it more of a radius. it might only take 1/16'' and radius that off. this is very cool, i've been wanting to do this for a while, just never had the gumption to research and do it myself. very cool thread.
Reply 0
Sep 1, 2010 | 01:51 PM
  #33
Thanks, Hopefully I will have a finished product to show you by the end of the week.
Reply 0
Sep 1, 2010 | 01:57 PM
  #34
lookin forward to it. also, the bryan tx area is a nice area. i have family all over tx and wish that i was there too.
Reply 0
Sep 2, 2010 | 06:25 AM
  #35
Thats nice. I have gotten everything in the mail except for my tubing so im waiting on that, should be here today or tomorrow. So far everything looks good for me but I was planning on drillin that hole out on the drag link and bolting it to the front instead of the back, I just figured it would'nt fit but your setup looks pretty nice!
Reply 0
Sep 2, 2010 | 07:07 AM
  #36
Quote: Thats nice. I have gotten everything in the mail except for my tubing so im waiting on that, should be here today or tomorrow. So far everything looks good for me but I was planning on drillin that hole out on the drag link and bolting it to the front instead of the back, I just figured it would'nt fit but your setup looks pretty nice!
I'll take another look & you should too, but I thought about putting in in the front also, but decided that as you turn the wheel your tubing will bind against the drag link. Also I did NOT want to drill out the drag link b/c at that point it could never be undone if you needed too.
Reply 0
Sep 2, 2010 | 07:13 AM
  #37
the bind is possible, i wouldn't try though. if you did drill and later on wanted to reverse it, you can get some tapers to fix the issue.
Reply 0
Sep 2, 2010 | 10:00 AM
  #38
I finished modifying the drivers side for clearance. I should get this wrapped up tonight.
Reply 0
Sep 4, 2010 | 05:12 AM
  #39
Tie rod end to Heim conversion is done! I got all of the clerance issues worked out & painted the adjusters black so they don't rust.
Reply 0
Sep 4, 2010 | 05:15 AM
  #40
do you notice any difference in the way it steers? and have you had the alignment done, im interested in what the alignment mechanic said.
Reply 0
