93 toyota wont start
Subscribe
Apr 19, 2009 | 07:22 AM
has spark, fuel, timing right on im baffled
Reply 0
Apr 19, 2009 | 07:50 AM
Since it sounds like you've checked the Battery, Ignition, and Fuel, you should check for air now. Remove the intake tube at the throttle body to see if it starts. If it doesn't then do a compression check. If compression is low and the intake tube is still off then loosen the exhaust and see if that makes a difference.
Reply 0
Apr 19, 2009 | 09:13 AM
how can you check the timing if it won't start?
what work's been done to the engine recently?
Reply 0
Apr 19, 2009 | 09:34 AM
Quote: has spark, fuel, timing right on im baffled
Tried turning it over?
Reply 0
