850 mile trip in the runner, some issues came up
Subscribe
Nov 23, 2009 | 03:36 PM
I've never heard the tractor engine origin. The engine is under-square, like a tractor engine and has also been used in fork lifts. Do you have anything to substantiate that?
I've held 4k up maybe 10 mile long steepish hills (climbing maybe 2-3000' or so???). No ill effects.
Reply 0
Nov 23, 2009 | 03:41 PM
I know that it can hold up 4K, I'm just saying that driving it at 90 for an extended period of time may not be the best for a 1989 truck with 225K miles.
That said, a few years ago I lost 5th gear and drove around all summer going 70 in 4th at about 4k. My timing chain eventually wore a hole through the cover and/or blew a head gasket.
My point was that if you want to make your truck last maybe just drive it a little more conservatively than going 90 on the freeway.
Reply 0
Nov 23, 2009 | 04:13 PM
Quote: Young man, I think you've got your head way up your butt!! Redline doesn't mean that's the RPM you drive it at for extended periods!!
Where have you been???
You obviously don't even know what "redline" RPM means??
gNARLS.
You might be right there old man, about the redline thing.... I'll take the rest of that under consideration. Where I've been has been running diesels my whole life and they never quit. I figured the bomb proof Toy drive train is at least equal to a 77 Scout II with the SD33NA diesel in it (just better looking).
I do know what redline means.... I also understand that 1600rpm before that is not a show stopper. I never said I ran at redline... hell I've very rarely borken the 4500 barrier.
I don't want to get into a peeing contest over this with you since you've probably done more wheeling than I'll ever see but don't be an a$$hole.
Reply 0
Nov 23, 2009 | 04:16 PM
There's a redline?
Reply 0
Nov 23, 2009 | 04:22 PM
  #25
Is there a blue line?
Reply 0
Nov 23, 2009 | 04:28 PM
  #26
Quote: OK, I won't be an a$$hole (well, I'm probably way past that!) if you can tell me what you think redline means??
Quick... do a google!!
gNARLS.
LOL now that was a great response! And yes I'll have to Google it to get the correct tech response back to you. As for what I know, from running diesels, the redline is a when the engine is turning rpm to a point at which the valve train and lubrication system can no longer keep up. This is the piont at which the engine begins to break down due to excessive heat and friction build up. (bacially the motor pops)
If that's wrong then give me a second or two on Google and I'll change that comment.
Reply 0
Nov 23, 2009 | 04:31 PM
  #27
Quote: Do diesel engines have a "redline"?? Where does it say anywhere that the Toyota 22RE engine is "bomb proof"??
A scout II with and SD33NA diesel wouldn't keep up with the stock 1985 Toyota truck in any race or off-road comparison!! A Scout is a respectable off-road vehicle, but no match for a Toyota truck!!
gNARLS.
Damn you type faster than I do.
Yes Diesels have a redline, or rpm max that is healthy. No a Scout II with the diesel would never keep up with a Toyota although in stock form a Scout will do a little better I think (with the diesel) off road. The only way to judge that would be to get an 85 Yota and an 80 Scout II and try them. I'd have to lean towards the Scout from prior knowledge.
Reply 0
Nov 23, 2009 | 04:33 PM
  #28
Junkers, I think you may be right in your assumption that the oil pump might be tired. That's what I was thinking on my old 87 when I saw the oil pressure drop after a while I just never fixed it and eventually sold with no issues.
At least it can hold up 90 MPH for a minute right?
Reply 0
Nov 23, 2009 | 04:37 PM
  #29
Toyota Recommends shifting between 2-4k rpms for 22r-e. That being said I would never push it no more than that. I think 75-80 is the fastest anyone should ever run a 22r. In japan the first related "R" engines were used japans light tractors and small farm vehciles and equipment, but later it was redesigned into a gasoline engine and used in alot of there cars. They made it into some of their patrol cars and even a few small ambulances. They first imported the "R" engine in america back in the late 50's in the toyota crown i think. and it at the time was a 1.5 liter tiny OHV cam in block engine. Made to be economical it didn't do well in america though.... IT was on par with lots of other engines at the time being cast iron block and water cooled..... just like most.... a few years later in the 60's when the toyota stout cam out i believe it had the 3R or the 4R i'm not sure then in the hilux cam out for the first time and also adoptded an R engine.....
Reply 0
Nov 23, 2009 | 04:38 PM
  #30
Quote: Naaaaaahhhhhh.... WRONG!!!!!
Redline RPM on an engine is the RPM BEFORE damage can occur to any components!!
So, you can take a stock 22RE to "redline" ... about 5600 RPM, but it won't produce any more power at redline.
Re-Google...
gNARLS.
Dang it! Ok so the redline is the stopping point before damage can occur? I got that... now. And the 5600rpm is the stopping point for more power? Is that right?
I thought it stopped making power at 3800rpm.
Reply 0
Nov 23, 2009 | 04:39 PM
  #31
wow........
Reply 0
Nov 23, 2009 | 04:40 PM
  #32
Quote: Junkers, I think you may be right in your assumption that the oil pump might be tired. That's what I was thinking on my old 87 when I saw the oil pressure drop after a while I just never fixed it and eventually sold with no issues.
At least it can hold up 90 miles per hour for a minute right?
It held 90mph for about 120 miles on open road (probably 300 miles all together on the trip). I'll change that pump though for my next run.
Reply 0
Nov 23, 2009 | 04:41 PM
  #33
Quote: Officially, no... but, "blueline" is about where you want to be running down the freeway at 75 miles per hour...
How's that??
gNARLS.
Man you and I have got to sit down over a glass of iced tea and talk Toyota engines. I need to pick your brain for a few hours.
Reply 0
Nov 23, 2009 | 04:42 PM
  #34
Red means stop....or dead....or wrong..... or no no.... or bad boy....or hot.....or fire.....or boom.......or BAM......or never.....or emergency....
Reply 0
  #35
Quote: If it stopped making power, as you say, at 3,800 RPM, then why would you drive it at 90 miles per hour at 4,000 RPM??
gNARLS.
When I hit the hills it would drop back into the power area and pull. No down shifting.
Reply 0
Nov 23, 2009 | 04:46 PM
  #36
Quote: Changing the oil pump won't make the oil pressure higher at 4,000 RPM at 90 miles per hour, and won't make the oil cooler.....
It's called thermodynamics.....
gNARLS.
Oh? So the gear driven oil pump stops producing oil at higher rpm? Damn that is something nice to know. Probably should have been in the owners manual.
Reply 0
Nov 23, 2009 | 04:48 PM
  #37
So, theres a yellow line?
Reply 0
  #38
Well by 4500k rpms the oil is moving so fast and so hot its practically water.
Reply 0
Nov 23, 2009 | 04:49 PM
  #39
^^So, you don't think the oil pump is the cause of lower oil pressure on extended periods of use? Is the oil just thinning out?
Reply 0
Nov 23, 2009 | 04:54 PM
  #40
Dances with the Stars....Ouch....Burn (that show sucks)
Reply 0
